3.0ltr Nissan motors
Submitted: Wednesday, Jan 18, 2006 at 03:35
ThreadID: 29819 Views:2809 Replies:6 FollowUps:10
I've read a lot of posts about the 3ltr Patrols blowing. Is the motor in the 3ltr Navara the same? Does it have the same type of problems? My daughter is planning to purchase one for towing horse floats. She wants a ute and it has the best towing rate.
Reply By: scottcamp - Wednesday, Jan 18, 2006 at 04:01
Hi Twinkles,
It seems to be isolated to the patrol 2000-2001 model as i have not heard many FIRST hand Navara drivers having problems. I have started a survey to determine the extent of the problem with the patrol but it does seem isolated to the early models. Also keep in mind it seems only to be an Oz problem, i am guessing either you work shifts or you are not from Oz by the time of your post. If you are from Europe then there seems to be no problem, maybe a fuel issue who knows. Or as a lot of people suspect a lot of the tales of the new ones blowing up are just that tall tales, from someone who knows someone whos uncles patrol blew up. But then again i am hoping the survey will provide some answers.
Scott
AnswerID: 149291
Follow Up By: Ron173 - Wednesday, Jan 18, 2006 at 07:26
I'd guess Twinkles is from Australia, 'ute' is not a word used in Europe.
Ron
FollowupID: 402449
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Jan 18, 2006 at 07:49
Scott the thought had crossed my mind too, with a lot more sulphur in our fuel until now. What effect that has on sensors that control boost, fuel and everything else in more highly tuned diesels has not been told. Companies like Mercedes and others have witheld their bigger higher tuned motors until now the fuel is coming to low sulphur standard the motors are being imported.
FollowupID: 402456
Follow Up By: Member - Phil G (SA) - Wednesday, Jan 18, 2006 at 08:36
Scott,
I remember hearing that they recalled and replaced the 3 litre motors in Portugal. Not sure about elsewhere.
FollowupID: 402468
Follow Up By: scottcamp - Wednesday, Jan 18, 2006 at 08:41
Hi Phil G
They recalled all them in the UK as well and i am sure someone also said Romania recalled them. But in answer to the original post no recall for the navara.
FollowupID: 402469
Reply By: Turbo Diesel - Wednesday, Jan 18, 2006 at 09:23
As mentioned on other posts I spoke to a mechanic at Highway Diesel in brisbane and he said that he was replacing a 2003 ZD30 that had just blown up for a Nissan dealership, he also mentioned that he had replaced replacement motors for the nissan zd30. Not sure if they where all out of just navaras but logic would tell you that they are the same motor in the both 4wds so both would suffer from the same problems.
AnswerID: 149327
Follow Up By: Member - toohey - Wednesday, Jan 18, 2006 at 16:51
g'day turbo not quite the same,navara does'nt have the intercooler or variable vane turbo.
cheers toohey.
FollowupID: 402646
Reply By: Member - Browny (VIC) - Wednesday, Jan 18, 2006 at 15:05
Twinkles,
I didn't think the ute had the 3 ltr, I thought all the utes were the 4.2ltr?
Then again I could be rong, it's happend before!
Cheers browny
AnswerID: 149398
Follow Up By: Truckster (Vic) - Wednesday, Jan 18, 2006 at 17:46
correct.. ute only comes with 4.2
FollowupID: 402666
Follow Up By: Member - toohey - Wednesday, Jan 18, 2006 at 18:09
g'day truckster
what would you call a navara tray back?whoop's maybe i should'nt ask:)
cheers toohey
FollowupID: 402672
Follow Up By: Truckster (Vic) - Thursday, Jan 19, 2006 at 00:46
manure. the patrol only comes in 4.2
FollowupID: 402777
Reply By: Eddy - Wednesday, Jan 18, 2006 at 21:40
At this point you seem to have plenty of replies but no one has answered your question.
I hope this improves for the sake of the forum.
Opinions are like a******s everyone seems to have one.
AnswerID: 149495
Reply By: Twinkles - Wednesday, Jan 18, 2006 at 23:02
I'm not sure I have a clear answer here. Thanks for the replies. I'm from the Mornington Peninsula south of Melbourne. Just couldn't sleep. Navaras are utes. They have a tub or tray and come with a 3ltr turbo diesel. Not interested in the petrol motor. The Patrol cab chasis only comes with the 4.2 ltr diesel.
AnswerID: 149510
Follow Up By: crfan - Thursday, Jan 19, 2006 at 00:38
Twinkles try Google.com
FollowupID: 402772
Follow Up By: Member - Browny (VIC) - Thursday, Jan 19, 2006 at 22:35
sorry twinkles,
Missed the "Navara" bit in you post.
will read more slowly in future
Browny
FollowupID: 403016
Reply By: arthurking83 - Sunday, Jan 22, 2006 at 14:54
Although the Nissans are cheaper than Toyotas, generally the Toyota will cost less in the long run............. :))
*oops!....ducks for cover!***
But you could save yourself a load of money alltogether, and get a LandRover diesel..Disco, Defender??
***Now this ought to be interesting :) ***
AnswerID: 150153
