sensor safe silicone
Submitted: Friday, Jan 17, 2003 at 21:53
ThreadID: 3002 Views:2993 Replies:5 FollowUps:1
Just a quick one. What the easiest sensor safe silicon to obtain (eg. local bunnings? Installing a safari snorkel on my 2000 turbo diesel hilux tomorrow and they call for it.
Reply By: Eric - Friday, Jan 17, 2003 at 22:46
Goodsy.
The one you want is neutral cure salastic, any hardware shoud have it.
Eric.
AnswerID: 11462
Reply By: Member - Peter- Saturday, Jan 18, 2003 at 17:26
Auto Pro in W.A has Sensor safe silicon and gasget cement
AnswerID: 11490
Reply By: Merv - Saturday, Jan 18, 2003 at 21:24
Goodsy.
If you can't get neutral cure silicone from a hardware you will definately get it from a glazing company. Neutral cure silicone is always used (or should be) when butt joining laminated glass.
Merv.
AnswerID: 11496
Reply By: goodsy - Sunday, Jan 19, 2003 at 00:39
Thanks guys found some, snorkel in no problems.
AnswerID: 11504
Reply By: Member - Andrew - Monday, Jan 20, 2003 at 13:10
How does normal silicone effect which sensor? I had no warning in my fitting instructions!!!!!!! AIRFLOW P.O.S.
AnswerID: 11570
Follow Up By: Goodsy - Monday, Jan 20, 2003 at 14:51
After doing a bit of research on the net I've found out it affects the O2 sensor in the exhaust. Fumes from the curing silicone when combusted destroy this sensor. Don't know how much of the silicon has to be used to do this though.
FollowupID: 6506
