Navara Fuel Filter
Submitted: Monday, Jan 23, 2006 at 19:41
J-Cadd
Has anyone fitted a Denco Fuel filter adaptor to their Z30 turbo diesel Navara or for that matter Patrol. I went to buy one today direct from Denco and they told me they do not recommend one being fitted to this motor. Anyone have one fitted having problems?
Reply By: dieselup - Monday, Jan 23, 2006 at 20:52
Out of interest if they dont recommend them did they tell you why?
Maybe, if your worried about
water you could fit a simple clear
water trap before the filter with a tap on the bottom so you can drain it if
water appears (before it reaches the main filter assembly) any good diesel service could point you in the right direction
150421
Reply By: J-Cadd - Tuesday, Jan 24, 2006 at 05:43
They don't recommend them for that motor because of the electric fuel pump
150502
Reply By: OldMike - Tuesday, Jan 24, 2006 at 09:49
Was told by Nissan mechanics, plus salesperson, if fitting aftermarket fuel filters, is ok to place a seperate unit BEFORE the origional but NOT to replace the origional. Good advice I think, because you should have the best of both worlds.
Mike
150519
