DUNLITE 3KVA 1.6KW ROTOR
Submitted: Friday, Jan 27, 2006 at 21:28
PE250
I HAVE A GENSET AS ABOVE COUPLED WITH A HONDA GX140
THE RINGS NEED CHANGING BUT I CANNOT FIND SOME ONE WHO KNOWS HOW THE ROTOR IS ATTACHED TO THE HONDA.
I SUSPECT IT IS THREADED ON BUT AM ASKING THE QUESTION BEFORE THE HEAVY MOB MOVE IN. THE UNIT IS ABOUT 12 YEARS OLD AND I HAD THE STATOR REWOUND FOR HEAVY USE ABOUT 8 YEARS AGO SO AM KEEN TO KEEP THE GEN GOING EVEN IF THE MOTOR IS REPLACED. IF ANY ONE HAS SOME ADVICE IT WOULD BE APPRECIATED.
CHEERS CHRIS
Reply By: Eric Experience. - Friday, Jan 27, 2006 at 23:09
Chris.
Is the caps lock button broken on your key board?
Some of the dunlites have a holow shaft in the armature with a long bolt into the end of the crank. Eric.
151376
Follow Up By: PE250 - Friday, Jan 27, 2006 at 23:39
THANKS ERIC BUT I AM A COMPUTOR ILITERATE. THE BIG STUFF MEANS I CAN READ IT. THERE IS NO BOLT IN THE END LIKE MY 32V ARMY GEN SET. GREAT FOR QUICK CHARGING A BATTERY AT 30 ODD AMPS. ANY HOW EXCUSE MY LACK OF ETIQUETE. ANY IDEA IF THIS IS A SCREW ON ROTOR??
CHEERS CHRIS
405017
Follow Up By: Morgan VIC - Saturday, Jan 28, 2006 at 13:09
Pity those in who do know cannot read it.
If you can post using the Internet you could be
well mannered enough not to shout at others when seeking assistance.
405085
Reply By: kesh - Saturday, Jan 28, 2006 at 07:34
Chris. When you take the alternator end cover off I think you will find an about 1/4" hex stud. Unscrew this,it goes right through the armature and into the end of the crankshaft. The armature is held onto the crankshaft simply on a longish taper, a good whack with a wooden mallet will release it.
They are not normally on a thread like
water pumps.
kesh
151394
Follow Up By: PE250 - Saturday, Jan 28, 2006 at 09:54
thanks kesh seems i have a brumby one. with the cover removed ( with the switch plate) there is a bearing on the end of a shaft but no bolts or stubs. i took the bearing off the shaft incase there was a grub screw bored lateraly under it but it is a plain old shaft. i hadn't taken the
water pump analogy so if the motor was a pump motor it is posible i guess. i have had 3 small motor mechanics look at it but they all just scratch their head and say buy a new one.
thanks any how regards chris
405049
Follow Up By: Morgan VIC - Saturday, Jan 28, 2006 at 13:14
The motor will be a GX140V with a tapered shaft. There is a stud in the crankshaft which screws into the end of the alternator. You need to be able to lock the flywheel and use a strap wrench to screw off the rotor.
You need the special factory tool to lock the rotor, or use another large strap wrench. DO NOT (used in expression of importance) attempt to jam something in the fins of the flywheel. While any tapered shaft is difficult to get off without the proper tools, the rotors with the bolt up the middle of the rotor and able to unscrew it from the end is preferable.
405087
Follow Up By: kesh - Saturday, Jan 28, 2006 at 17:44
And thanks from me too,
Morgan.
Am always pulling something or another apart, and not encountered that system before.
A little bit more knowledge to store, but thats never a hardship.
cheers the kesh
405123
Follow Up By: PE250 - Saturday, Jan 28, 2006 at 19:27
thanks
morgan it was easier than i had imagined. the special factory tool was a oil filter remover and after stuffing a soft rope in the barrel on compresion stroke i got my off sider to hit the end of the shaft with a drift as i applied presure and it spun off no problem.
to the cap locks comment be alittle patient we arn't all up to speed whith the internet, if you hadn't guessed i cannot even type.
thanks for the help
cheers chris
405132
