Patrol & UHF positioning
Submitted: Saturday, Jan 28, 2006 at 23:53
Darren C
Hi All
Am trying to find something like velcro to stick the uhf to the carpet on the side of the front passenger footwell in the Patrol. The velcro I bought will simply not adhere to the carpet (although it sticks fine on the dashmat carpet). Anybody know of anything that will do the trick?
Alternatively has anybody got any other suggestions of how to temporarily mount an UHF inside the car (GU4) without drilling holes?
Reply By: Member - Captain (WA) - Sunday, Jan 29, 2006 at 00:04
Hi Darren,
Cable ties do wonders!
Captain
151559
Reply By: Exploder - Sunday, Jan 29, 2006 at 02:58
Had a similar problem as you do, tried the Velcro and so
forth but in the end opted to drill 3, 3.5mm holes and use screws to secure it.
The way I look at it is the holes are that small and in such a location that with a bit of Epoxy risen to fill, followed with a light sand, unless you look real close they would hardly be noticeable (If I choose to remove the UHF when selling that is).
151568
Reply By: Brett_B - Sunday, Jan 29, 2006 at 09:11
I used cable ties to secure my TX 3400's main unit under the dash, placed a piece of rubber pading between it and the mounting point to soak up and vibration and rattles.
I dont have a Nissan but maybe this is still an option for you.
Like you I didnt want to drill holes.
Brett
151578
Reply By: olcoolone - Sunday, Jan 29, 2006 at 12:10
Hello darren, you may want to have alook at mounting your radio in the storage bin in the centre consol, it's out the way and safe.
I have tried velcro but found the heat inside the vehicle affects the glue on the back.
Regards Richard
151598
Reply By: Member - Luxoluk - Sunday, Jan 29, 2006 at 12:19
A good quality 3M double sided tape will adhere
well to plastic and painted surfaces. Will hold a remote head with ease. Cheers
151599
Reply By: parthy - Sunday, Jan 29, 2006 at 17:12
GO ON DRILL THE HOLE I DARE YOU THE FIRST HOLE IS ALWAYS THE HARDEST IT COMES NATURALY AFTER THAT
151620
Reply By: SteveL - Sunday, Jan 29, 2006 at 21:36
Get a Motorola syntrx then you only need to hang the mike somewhere;-) -Steve
151671
