GQ with leaves
Submitted: Thursday, Feb 02, 2006 at 01:31
ThreadID: 30339 Views:5548 Replies:6 FollowUps:3
Gday, just a quick question for anybody please. I have a LWB GQ with coils all round. I am looking at a s/hand bull bar that comes from a GQ ute.
I know they made GQ utes with leaf rear end, I have heard that these utes have different width chassis rails. Is this right or just the utes that look like a MQ?
Is there any situation where this bull bar wouldn't fit my fourby?
Barnesy
Reply By: Truckster (Vic) - Thursday, Feb 02, 2006 at 01:39
GQ Utes with Leaves are designed to carry more weight. You can get GU with coil or leaves, or could when they first came out. Dont know about now.
From what Ive read on OL, they are same chassis width.
AnswerID: 152420
Follow Up By: Member - Davoe (Widgiemooltha) - Thursday, Feb 02, 2006 at 19:10
Still can the testra are leaf sprung
FollowupID: 406320
Reply By: Member - John - Thursday, Feb 02, 2006 at 07:02
Barnesy, the leaf sprung Nissan ute, GQ and GU, has wider chassis rails at the rear, as far as I know, the rails at the front are the same width.
John and Jan
AnswerID: 152428
Reply By: Member - Brian (Gold Coast) - Thursday, Feb 02, 2006 at 07:42
I had a bull bar on my GQ wagon that was originally from a leaf sprung ute..... it was an absolute bitch to fit and didn't "sit" properly anyway. As well, it seemed loose, as in, I could move it back and forth on the holding bolts although I couldn't tighten them any tighter.
Save your $$'s and get an newie...... my experiment cost me $200 for a bar I couldn't use, couldn't sell, and ended up throwing on the tip.
AnswerID: 152432
Reply By: desert - Thursday, Feb 02, 2006 at 10:49
You have to be a bit careful here, as the change over to GQ was a little blurred with the utes around 1989. There was a GQ that had the MQ front guards and leaf springs both front and back. This chassis is neither MQ or GQ, but a mongrel unit that filled the model gap prior to complete change over to Coil front end and the wider body bits. So, I'd reckon a bar for this model would be closer to an MQ chassis, but still MAY have to be altered. A bit like the deal with the G61 which filled the gap prior to MQ in 1979. There is a leaf GQ at work, so I could measure the chassis spacing for you if you so desire.
AnswerID: 152478
Follow Up By: Barnesy - Thursday, Feb 02, 2006 at 12:03
Thanks fo replying. So if the ute has coils up front with the flared guards like on other GQ's then it would fit you think?
I'm right in saying the utes looking like a MQ with leaves up front are the ones with different chassis width?
Barnesy
FollowupID: 406214
Follow Up By: desert - Thursday, Feb 02, 2006 at 14:06
Correct.
FollowupID: 406241
Reply By: parthy - Thursday, Feb 02, 2006 at 20:12
Try these guys if they dont know no one dose http://www.patrol4x4.com/forum/
AnswerID: 152572
Reply By: Member - Pezza (QLD) - Thursday, Feb 02, 2006 at 20:15
Barnesy,
The GQ utes with leafs up front are a different width, I had a bar of a coil spring wagon for sale and a bloke turned up with a leaf GQ ute, we measured the distance and there was quite a substantial difference, memory's not that good on which way it went but I think the leaf spring version is narrower.
If the one you are looking at is a coil spring I can't help you, but just measure it to be sure.
Avagoodn
Pezza
AnswerID: 152575
