UHF To Fit
Submitted: Saturday, Feb 04, 2006 at 04:51
ThreadID: 30399 Views:2220 Replies:3 FollowUps:3
Can any help with suggestions of a good UHF to fit in a Nissan Navara dash.
Reply By: Member - toohey - Saturday, Feb 04, 2006 at 06:22
GME TX3200
AnswerID: 152864
Follow Up By: Pluto - Saturday, Feb 04, 2006 at 07:56
I would agree. Either the TX3200, 3400 or any small format tranceiver.
I mounted my Tx3200 to my Patrol below the dash, on the panel that meets the central hump, so that it sits between the gear sticks and the dash. It required a wooden spacer, but ended up looking like an integral part of the dash. It also didn't require an external speaker as the inbuilt faced into the cabin.
FollowupID: 406669
Follow Up By: Member - toohey - Saturday, Feb 04, 2006 at 11:34
TX3200
fits in pocket above the radio
cheers toohey
FollowupID: 406720
Reply By: MattyM - Saturday, Feb 04, 2006 at 08:48
You can use any UHF with a DIN mounting kit. If you pull out the radio & the that little storage pocket you can fit the UHF in the radio bracket.
I fitted a TX3200 with the DIN mounting kit to my Navara & a mate used a TX4400 in the same spot. It sits in the dash properly & looks like it was meant to be there.
Matty
AnswerID: 152877
Reply By: roofscooter2 - Saturday, Feb 04, 2006 at 09:31
gme 3600 split system works well also ( did in my f250) regards ,bob.
AnswerID: 152886
Follow Up By: roofscooter2 - Saturday, Feb 04, 2006 at 21:00
sorry misleading info, should be gme 3400 split system,cheers bob.
FollowupID: 406875
