Shelf life of oil.
Submitted: Saturday, Feb 04, 2006 at 13:59
guzzi
A query to the oil savvey,
Just what is the rough useable shelf life of synthetic oil?
The reason I ask is 4 yrs ago I aquired 51 ltrs of synthetic engine oil for a good price from the oils then distributer.
As the bike its used in no longer does the KM it used to due to family comittments and a newly aquired addiction to 4wds, Ive used less than half of what I though I would over the last 4 years. On current usage the last of it will be 8 years old by the time it gets used.
Kept in the garden shed -2 to 40degC temp range.
No I havent got on to the manufacturer/distributer yet, thought Id ask here first.
Comments??
Reply By: Flash - Saturday, Feb 04, 2006 at 14:57
My guess in a good sealed container...
indefinite. Many years as long as it's a GOOD container- I've used 20 year old transmission oil in a bike with no problems.
Only factor I think would be that newer oils are always getting better.
152945
Reply By: theshadows - Saturday, Feb 04, 2006 at 17:39
err couple of thousand years should be all right.
Hey there is an idea I might buy 4 barrels of crude... imagine how much it be worth in 20 years......
it be better than winning the lotto
shadow
152972
Reply By: Member No 1- Saturday, Feb 04, 2006 at 18:55
oils (synthetic or mineral) have a high infinity for moisture.....even in sealed drums/containers...hot weather they expand ...expell some (albeit very small amount) air and then contract when its cold, sucking in fresh air along with some new moisture.....moisture condenses and is absorbed by oil until saturation and in extreme cases it then begins settles on bottom of container.
either way its going to have more moisture (PPM) than manufacturers specs
do you trust the conatiner to be perfectly air tight?.....its your call?
moisture and oil together with heat and wear metals from engine causes acids...not to mention residues from detonation in combustion chamber
152992
Reply By: Member - laura B (NSW) - Saturday, Feb 04, 2006 at 20:29
hi,
work for
caltex and never been told that oil has an expiry date,then again we sell oil like its petrol!! i would say its ok, have a look at it,smell it rub a little through ya fingers and see how it is...if its synthetic it should be green? i think! if there is
water getting into it it should be sitting on top because they dont mix. I'd use it..temperature shouldnt worry it....it gets hot in the car anyway.
good luck,
Laura B
HAPPY INSIDE WHEN IM OUTSIDE
153001
Reply By: macca172 - Saturday, Feb 04, 2006 at 22:01
This is a little of the track, however the US Navy have a team that go around the sunken WW2 ships(shallow) in the South Pacific that are seeping their fuel oil and are contaminating the local habitant. They hook into the fuel tanks of these sunken vessels and pump the contents into a receiving vessel on the surface. In most cases after the fuel is returned to the USA, it is refined and reused in todays market. Not bad for 60 years on the bottom. I saw this on a doco on SBS about two years ago.
153012
Reply By: Member - Phil G (SA) - Saturday, Feb 04, 2006 at 22:19
I've heard that oil doesn't go off with time. I'd still be using it.
153022
Reply By: Mr Fawlty - Sunday, Feb 05, 2006 at 14:31
Synthetic oil should be ok...check the inside of the drum though to see if there is any rust before you use it.... I have been told by my Castrol agent that Synthetics are not hygroscopic but mineral oils can be.
153135
