Biodiesel question.
Submitted: Tuesday, Feb 07, 2006 at 21:03
ThreadID: 30534 Views:2344 Replies:5 FollowUps:7
Hi Guys,
A friend of mine has started using Biodiesel in his 3lt Surf, he is on his second tank and is telling me his fuel economy has dropped off by 100km a tank (60lt tank so quite a lot).
Anyone had a similar result?
Reply By: Member - David 0- Tuesday, Feb 07, 2006 at 21:10
Should be better, as it is generally higher octane and better lubricity.
Sometimes causes blockages of filters and such but I've not noticed reduced econmomy
AnswerID: 153716
Follow Up By: desert - Tuesday, Feb 07, 2006 at 21:28
Just a technicality, but diesel fuel has a cetane rating, not octane.
FollowupID: 407620
Follow Up By: Member - David 0- Tuesday, Feb 07, 2006 at 21:32
Yeah I couldn;t think of the word, and I'm a flamin chemist....brain dead. :-)
FollowupID: 407622
Reply By: Vivid Adventures - Tuesday, Feb 07, 2006 at 21:12
If he hasn't replaced his fuel filter, I'd suggest his fuel filter is clogged with the rubbish that has collected in his fuel system over years of dinosaur diesel.
I did replace my fuel filter after the first tank, and the collected deposits are quite evident. Now my economy seems better - but I don't have too much scientific data to go on.
Would strongly recommend he do that if he has not already?
Ciao for now
Andrew.
AnswerID: 153718
Follow Up By: 1KZ-Mick - Tuesday, Feb 07, 2006 at 21:33
Thanks, I'll suggest that to him.
Mick.
FollowupID: 407623
Reply By: Footloose - Tuesday, Feb 07, 2006 at 22:56
AFAIK this is fairly normal, but it should be more than offset by the cheaper price of biodiesel. Is is cheaper isn't it ? Or is this just another example of having to go into the red to be green ?
AnswerID: 153748
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Feb 08, 2006 at 07:20
Its about 10cents a litre cheaper, but as diesel prices climb, watch the biodiesel prices climb,,,, funny about that..
FollowupID: 407681
Reply By: Snowy 3.0iTD - Wednesday, Feb 08, 2006 at 08:37
Mick
Although Biodiesel has higher lubricity and is better for the environment I recall reading somewhere that it actually has a lower energy value than ordinary diesel. This makes sense to me, as every time I have tried it, I get poorer fuel consumption figures, and noticeably less power under the right foot.
Snowy
AnswerID: 153789
Follow Up By: Vivid Adventures - Wednesday, Feb 08, 2006 at 08:40
perhaps you are cleaning out your fuel system with it too?
Get your fuel filter replaced next service!
Ciao for now
Andrew.
FollowupID: 407686
Follow Up By: Member - Oldplodder (QLD) - Wednesday, Feb 08, 2006 at 09:01
The cetane rating of the biodiesel depends on the oirginal type of vegetable oil used. Some give a lower and some give a higher cetane rating than petroleum based diesel. But there is an assie standard coming in which will solve the problem.
So doubt it is cetane rating, try your filters.
FollowupID: 407694
Follow Up By: Snowy 3.0iTD - Wednesday, Feb 08, 2006 at 09:02
I did all the reccommended stuff including replacing fuel filters, have used it on multiple occasions, and I would have thought that a blocked fuel filter would lead to fuel starvation and lack of power, but can not see how it would increase fuel consumption.
Snowy
FollowupID: 407696
Reply By: viz - Wednesday, Feb 08, 2006 at 20:49
Wonder how they go with common rail diesels - which use much finer nozzles. Filtration is a much greater issue with this type of injection system...
/viz
AnswerID: 153929
