Navara zd30 blown
Submitted: Tuesday, Feb 07, 2006 at 21:57
ThreadID: 30540 Views:3866 Replies:4 FollowUps:2
A mate of mine has a 03 navara with the zd30 turbo engine. The engine got dusted some how and began to knock. I organized a wrecking yard in Adelaide to fit a second hand motor which was out of a patrol same year. They put the two motors side by side and they have a different bolt pattern for the gearbox!!. None available in Adelaide so its coming from Melbourne. Just thuoght others might like to know before they go to the trouble.
Reply By: Fusion - Tuesday, Feb 07, 2006 at 22:47
An '03 Navara would still be under warranty unless it was Jan '03, or had done more than 100,000km's. Even then you could buy another 2yrs and 50,000 for about $900.
Interesting that the gearboxes don't match up though.
Aaron.
AnswerID: 153744
Follow Up By: rv129 - Tuesday, Feb 07, 2006 at 23:10
Navara has done 150k so no warranty but we did try!! It was not really a mechanical fault it just wore out real quick due to dusting.
FollowupID: 407657
Reply By: Nav 8 - Tuesday, Feb 07, 2006 at 22:58
Hmmmm,,nearly had a bad turn when I read that post,but if the engine was dusted well thats not the engines fault. I would say warranty would be out of the question also. Nav.
AnswerID: 153749
Follow Up By: scottcamp - Wednesday, Feb 08, 2006 at 02:23
Ehhh, excuse my ignorance but what is "Dusted" and how does an engine get dusted.
FollowupID: 407678
Reply By: rv129 - Wednesday, Feb 08, 2006 at 08:23
Dusted is when an engine suxs in a lot of dust either from a intake hose coming off or leaking vacuum or the air cleaner not being serviced regularly. Also if the air cleaner is damaged or not sealing. Not sure what caused this one but it may be lack of mantenance. Dont get me wrong I dont blame Nissan or the ZD30 engine just wanted to let people know that for some reason the Navara and Patrol use a diferent engine!!!
AnswerID: 153787
Reply By: Member - Toonfish - Tuesday, Feb 21, 2006 at 21:45
at least zd 30's are designed for quick changes nowadas lol
AnswerID: 156347
