Fitting a HF Auto Tune Aerial
Submitted: Thursday, Feb 23, 2006 at 18:31
Member Rough it
Hi all.
Just purchased a new Barret 2050 HF. Any suggestions on mounting bracket for Auto Tune Aerial on rear of vehicle on a Nissan Patrol GU
Thanks Rough_it
Reply By: Old Scalyback & denny - Thursday, Feb 23, 2006 at 18:40
goodday
you can buy or build your own bracket that bolts in behind the spare wheel
steve
156711
Follow Up By: Member Rough it - Thursday, Feb 23, 2006 at 19:22
Thanks Steve
do you no where i can buy one
410814
Reply By: Member - Paul P (Bris) - Thursday, Feb 23, 2006 at 18:44
G'day
I use this mount on my GU and it works
well with my Codan. HF mount
My codan auto tune ends up about 300mm above the roof line. The Barret I believe is shorter in the autotune body so may not put your vehicle height above 2 metres with the antenna removed.
Alternativley look at at Kaymar or ARB rear bumper replacement bars with the HF antenna mounting option.
Paul
156714
Reply By: Darian (SA) - Thursday, Feb 23, 2006 at 19:56
G'day Roughy - this mob in the northern outskirts of
Adelaide make brackets to suit a variety of vehicles - guess yours would have to be one - as mentioned above, they bolt on with your spare wheel mounts - quite compact and tidy - the one for my Jackaroo resulted in the top of the autotune being level with the roof (as it should be) - their pattern should result in the same for you. Installation is easy - routing of the cables for durability may be another issue. There should be other GU owners by the score that have put in a 910 autotune but.
http://www.aus4wdstor.com/home.htm
156728
Follow Up By: Peter Schrader - Friday, Feb 24, 2006 at 00:25
Lake Macquarie comms supplied my bracket for the rear wheel carrier.
Works a treat and looks pretty good too.
410912
Reply By: BenSpoon - Friday, Feb 24, 2006 at 11:08
Got a spare wheel carrier? If so, see if your base will fit between the car and the spare and get it mounted on there. Head to a metal Fab
shop and get them to make up a mount.
Mine set me back $50 cash- cut, welded, installed, and its solid enough to mount a vice on it. I had to paint it myself, but at that price I was laughing.
156830
