where to put second battery in a pajero
Submitted: Thursday, Feb 23, 2006 at 20:35
peter d
hi all, a work mate has a pajero (not sure of year, in the 90s) and is thinking of putting in dual batterys. where do they put them as he doesn't think one will fit. i haven't looked under his bonnet as yet but any ideas would be appreciated. thanks.
peter d
Reply By: South - Thursday, Feb 23, 2006 at 20:41
They sit up against the firewall on the passengers side. The Carbon Cannister needs to be moved, ours is fitted right at the front, near the bash plate, near the swaybar. Just bolted the bracket in where some holes were perfectly set, and extended the hoses.
Piranha make a very sturdy battery tray that is around the $100 mark, and Redarc make an excellent smart solenoid, again around the $100 mark.
156742
Follow Up By: peter d - Thursday, Feb 23, 2006 at 20:53
South thanks for that . i just been looking back in the
forum and found one that said the same . thanks again. peter d
410844
Reply By: GREENDOG - Thursday, Feb 23, 2006 at 21:42
Hi Pete I have a 91 NH Paj and yes it sit's right on the fire wall on the passanger side i have a pirana duel batt system fitted and works
well,hope this helps.cheer's GREENDOG
156761
Reply By: Member - George (WA) - Thursday, Feb 23, 2006 at 22:29
whilst on the subject of battery placement, where do you fit a 3rd battery in a 100 series Turbo Diesel Sahara. The Sahara already has 2 bateries as standard and I have been told that they cannot be isolated. What can you do for an auxilary battery.
Any suggestions / advise would be appreciated
156768
Follow Up By: Richard - Friday, Feb 24, 2006 at 11:45
Had a 2001 NM Pajero and put a 2nd sealed battery in the rear seatwell with the Pirahana isolator under the passenger
seat and the cable running through the firewall grommet and under the mats. When I bought the TD100 I just transplanted the setup with the third battery down the back. I have a fused 300W inverter for charging camera and phone and 3 fused 16amp sockets for the Fridge, Fluro etc.
410979
Reply By: Derek from Affordable Batteries & Radiators - Thursday, Feb 23, 2006 at 22:32
The Redarc is great for your mates application and I also use the odd Piranha battery tray if I don't have one in stock to suit.
Piranha part number Btmpo suites up to 1990 and Btmpn suites 1991 onwards LWB only.
He may also want to look at a 12v Power Pack if he wants an easy solution.
Opp. Lock have one similar to
mine. Just a matter of choice.
Regards Derek.
156770
Reply By: peter d - Friday, Feb 24, 2006 at 19:30
thanks everone, been a great help. will be having a look at it this weekend.
peter d
156911
