BFG ATs Tyres Sizes?
Submitted: Friday, Feb 24, 2006 at 22:21
ThreadID: 31123 Views:5174 Replies:5 FollowUps:1
Hi All
Can somone please tell me the difference in a BFG AT 265x70x16 and a 265x75x16?
And will a 265x75x16 fit under a standard 2001 td prado and not hit any wear?
Are they a good wearing tyre? i have 265x70x16 grandtreks h/t on and want to go a/t nothing wrong with the grandtreks if anyone no someone wanting a good cheap set of tyres around 85% tread left
Thanks Jon
Reply By: Exploder - Friday, Feb 24, 2006 at 22:35
2/10ths of F-all
Overall diameter
LT265/75R16/ 283
LT265/70R16/ 792
Higher load index
Same speed rating
Max rim size on the 75's is a 8, 70's are 8.5
AnswerID: 156936
Follow Up By: Exploder - Friday, Feb 24, 2006 at 22:40
Excuse the butter fingers
LT265/75R16/ 283
“283” Should read 820mm Vs 792mm for the 70 series for the overall diameter
FollowupID: 411114
Reply By: Jim Evans - Friday, Feb 24, 2006 at 23:23
I have just fitted 265x75x16 BFG A/T's on my Patrol in place of the original Bridgestone 265x70x16 tyres. These tyres are almost exactly 1/2" (13mm) bigger in the radius than the originals. That means 13mm more ground clearance and about 5% increase in the rolling circumference. Net result is that the speedo now reads almost exactly correct where before it was 6% fast. At a calculated 100 Km/hr it now reads 101 where before it read 106.
You may find that the steering is fractionally less precise due to the higher profile.
Can't comment on guard clearance issues with the Prado - no probs with the Patrol.
AnswerID: 156940
Reply By: OLDMAGPIE - Friday, Feb 24, 2006 at 23:46
why change? wait till the others r worn, the grandteks h/t will run on dirt ,cheers
AnswerID: 156943
Reply By: Member - TonyG (Qld) - Saturday, Feb 25, 2006 at 08:36
Hi Johnboy,
When our tyres were up for replacement on the patrol, we went with the BF Goodrich AT 265x75x16.
We found the following
- tyres were cheaper - apparently 75 series is a more popular tyre, hence sell more and so they can discount them better
- Car is 1/2 inch taller
- Far better ride than original tyres
I would recommend going this way
TonyG
AnswerID: 156958
Reply By: jonboy - Saturday, Feb 25, 2006 at 22:05
Thanks everybody for your help
Thanks Again
AnswerID: 157073
