Landcruiser Rear Screen Washer
Submitted: Monday, Feb 27, 2006 at 22:06
Parso
Just got the new '98 LC RV Diesel and have found that the rear windscreen washer motor operates but is not pumping at the screen. Anyone have some ideas?
Parso
Reply By: Tim M - Monday, Feb 27, 2006 at 22:17
If the
water is spraying elsewear then stick a pin in the nossle and adjust towards the glass
157396
Follow Up By: Parso - Monday, Feb 27, 2006 at 22:25
No, there is no
sign of
water anywhere. That's the mystery.
411668
Reply By: Dave198 - Monday, Feb 27, 2006 at 22:44
The plastic tube inside the door leading to the jet split on my 60 and I replaced it with a new piece right from the waterbottle.
Check inside the door panel after you activate the washer and see if there is any
water inside the doorframe.
157404
Reply By: japmel - Monday, Feb 27, 2006 at 23:05
The little jet where the
water comes out will be blocked.
Try
clearing it with a pin while someone is activating the pump.
japmel
157408
Reply By: Member - Troll 81 (QLD) - Tuesday, Feb 28, 2006 at 05:30
I had that problem before, the fix was unplugged it at the pump and got the air compressor into it and blew all the gunk out
157446
Reply By: Shane (QLD) - Tuesday, Feb 28, 2006 at 08:08
On the 60 Series Cruiser there is a non return valve in the plumbing in the rear door. This can block up & no amount of pressure from both ends will shift the blockage. I got rid of
mine, but it now takes a little longer to pump from the motor to rear screen.
157459
Reply By: Member - Davoe (Widgiemooltha) - Tuesday, Feb 28, 2006 at 09:10
I was getting one side of my
barn doors wet only. it turned out when one of the doors was closing it was kinking the pipe - could be worth a look although yours is a different setup
157470
Reply By: Parso - Tuesday, Feb 28, 2006 at 18:47
Thanks guys!
Heaps of ideas on the cure for the problem and I will get to it on the weekend.
My bet it is the non-return valve as the rear wiper/washer circuit has not been operational for some time.
157590
Reply By: Geoff M (Newcastle, NSW) - Tuesday, Feb 28, 2006 at 21:36
Fill the bottle?
| Geoff,
157642
