Engel running on 24 volt
Submitted: Wednesday, Mar 01, 2006 at 13:12
ThreadID: 31287 Views:14006 Replies:3 FollowUps:8
Hi All, can anyone tell me which model engels will run on 24v and 12v, the old green lidded models were only 12v I believe. Mine is a 29l grey model with dark lid but off hand dont know exact model/date (bought it 2nd hand). Want to run it in my truck which is 24v and would rather not have to fit a reducer to bring it back to 12v if not necesary. thanks..
Reply By: Member - John L G - Wednesday, Mar 01, 2006 at 13:25
Zapper
I'm pretty sure they are 12v DC and 240V AC. Haven't heard of any Engel having a 24V input, then again - I may be wrong.
Does the truck have 24 volt batteries or is the 24 volt achieved by 2 x 12v or 4 x 6V batteries being wired in series. If the latter, you could steal a feed from one of the 12 volt batteries or two of the 6V.
If the truck is not a toy 4WD Nissan or Tojo but a real one, read large and imposing, then I would assume its a work vehicle and constantly on the move. If so stealing the 12V from one of the batteries should not pose a problem.
John G
AnswerID: 157826
Follow Up By: Zapper - Wednesday, Mar 01, 2006 at 13:30
Hi John
yep its a mitsi 8 tonne. Has 2 x 12v. I have used that method (running off the 1st battery direct) previously and in fact thats how my CD player is running, however I know from past experience the battery that has the 12 volt draw on it always seems to last a lot less time than the one on the 24v side. The new Engels will run direct on 24v, thats what the website says anyway
FollowupID: 412129
Follow Up By: Member - Tony G (ACT) - Wednesday, Mar 01, 2006 at 13:38
I think the older ones were either 12 or 24 not both.
FollowupID: 412132
Follow Up By: Ron173 - Wednesday, Mar 01, 2006 at 14:05
Hey John,
Dont you reckon you'd better run for cover with statements like that on here mate!! LOL shall watch with interest.
Quote 'If the truck is not a toy 4WD Nissan or Tojo but a real one' unquote
Ron
FollowupID: 412142
Follow Up By: Member - John L G - Wednesday, Mar 01, 2006 at 14:27
Old dog - Old tricks but now with new knowledge re 24V.
As for "Toy Trucks" - safe at the moment and firmly in Tojo territory as hiding in Tom Price for a month.
Bit wet up here at the moment tho it was interesting to see the guy in Karratha do a flotation test on his PLaydo in the Turner River last night.
Best pic ever saw was two blokes sitting on the roof rack rack of their swept away Tojo P/C 47 series in the middle of a river with fishing rods and XXXX in hand. Classy act!
John G
FollowupID: 412150
Follow Up By: Tim HJ61 (WA) - Wednesday, Mar 01, 2006 at 14:40
John L G,
PLEASE PLEASE don't run a fridge of the centre tap of a 24v system to get 12v without making other alterations. i.e. It is not correct to say "so stealing the 12V from one of the batteries should not pose a problem".
It WILL create problems, unless the battery voltages are equalised. Redarc sell a device to do this. If the level of charge in each battery is not balanced by an external device, the batteries do not do this all alone - unlike when they are in parallel. One battery will be overcharged and die of being boiled dry, the other battery will die because it is undercharged.
The other alternative is run 12v items via a 24v/12v reducer, but draw is limited by the devices capacity, unlike the balancing device that allows high current draw which is then balance back over time.
There are many comments on this in other threads for more details.
Tim
FollowupID: 412156
Follow Up By: Member - John L G - Wednesday, Mar 01, 2006 at 15:01
Tim
Old dog - NEW trick.!!!!
Think that just might answer the original post.
Thanks for the input.
John G
FollowupID: 412159
Follow Up By: Derek from Affordable Batteries & Radiators - Wednesday, Mar 01, 2006 at 15:11
MRFD015 12 VOLT ONLY
MT17F 240V AC / 12V/24V DC
MT27F 240V AC / 12V/24V DC
MT35F 240V AC / 12V/24V DC
MT45F-S 240V AC / 12V/24V DC
MT60F 240V AC / 12V/24V DC
MT60F COMBI FRIDGE FREEZER 240V AC / 12V/24V DC
MT80F 240V AC / 12V/24V DC
MT80F COMBI FRIDGE FREEZER 240V AC / 12V/24V DC
SR90E BUILT IN CARAVAN FRIDGE TO REPLACE OLD DOMETIC 240V AC / 12V/24V DC
All the new ones are auto switching from ac to dc and back.
Regards Derek
FollowupID: 412161
Follow Up By: Tim HJ61 (WA) - Wednesday, Mar 01, 2006 at 15:31
Thanks Derek,
That's not an exhaustive model list.
Mine is an olive green lid 27l model from around 1979. Model MRFT-530-A4 .
The internal inverter specs say 12v input, output 20v AC. The label on the input plug says 12V/240V, so though I'd prefer to run on 24v and have the ability to do so, I'll be leaving mine on the 12v.
It's not that hard to search the Engel website and find info out direct from the source. www.engelaustralia.com.au then go to products then to past products. I found mine listed there, confirming the specs above.
Tim
FollowupID: 412166
Reply By: Member - Sam (NSW) - Wednesday, Mar 01, 2006 at 13:49
I was under the impression that most of the models were 12, 24 and 240 Volt. I am pretty sure my 40L will handle one of either of the 3 voltages
AnswerID: 157834
Reply By: Ron173 - Wednesday, Mar 01, 2006 at 14:03
Zapper,
all current Engels from the 17 upwards all support 24v.
As you dont know age of yours prob best to contact Engel with serial number and check before you fire it up. no pun intended!!
this link may help but they are not the worlds quickest email reply service!
Ron
AnswerID: 157838
