Nissan Injector Pump
Submitted: Thursday, Mar 02, 2006 at 07:50
ThreadID: 31319 Views:2588 Replies:3 FollowUps:0
I notice the replies to post just below about an 80s Cruiser which has a leaking injector pump indicate it is possible to fix yourself in as little as 30 mins.
Is this the case for the injector pump in a GQ? Mine has been leaking for ages but have been holding off on getting it repaired due to the cost, about $1500 I believe so if i can do it myself in 30mins (or even 3 hrs) I'll have a go
Jim
Reply By: traveller2 - Thursday, Mar 02, 2006 at 08:15
Depends on which seal is leaking, also the 1HZ (80 series) is a rotary pump while the GQ is an inline one.
The inline ones are generally much more complicated and more expensive to fix but do last much longer.
The rotary pumps are lubricated and cooled by the fuel flowing through them. Whereas the inline ones are lubricated by the engine oil and only slightly cooled by the fuel.
In simple terms think of a minature six cylinder engine for the inline and a distributor on a petrol motor for the rotary ones.
The older inline pumps will suffer leaks due to low sulphur fuels drying out rubber based seals whereas most of the rotary pumps have vitron seals able to withstand the lack of lubrication.
AnswerID: 158010
Reply By: JamieMac - Thursday, Mar 02, 2006 at 13:20
My GQ had a rotary pump (as does my GU) and it did leak after the introduction of low sulpher diesel in QLD and then again in NSW.
Original leak was at the top cover and had that refaced and repaired by a diesel mob in Townsville for about $200 dollars.
Second leak was from the outside/RHS cover plate of the pump assembly. Can not remember what was under it. I did fix this bit myself with a $3 o'ring in less than an hour or so as I am pedantic. Access was a problem to the inside/LHS one so I left it alone as it was not leaking at the time. Have since sold the vehicle. Would have attempted the inside one myself also if required.
JamieMac
AnswerID: 158079
Reply By: Billowaggi - Friday, Mar 03, 2006 at 01:01
Hi Batboy, Toyota 80's and GQ, GU 4.2 are the same Bosch VE pump, usual leak is from the top cover ,part is about $14 you can do it yourself but has potential traps! There is spring loaded parts inside and also the throttle arm has to be removed [to replace an o ring] and must go back in exactly the same position. If you do not feel confident hunt around for a mechanic that can do the seals with the pump 'in situ' there should be ptenty around as this is a common replacement.
Regards Ken.
AnswerID: 158258
