Polystyrene Sheeting
Submitted: Friday, Mar 10, 2006 at 18:15
Ray Bates
I am after some 50mm polystyrene sheetint to insulate my caravan fridge. Anybody in
Perth know where I can buy it.
Thank you
Reply By: Raymond from Wanderin 4 Wheelers - Friday, Mar 10, 2006 at 18:19
Hi Ray
If it is a caravan fridge and a built in then it is worth getting the industrial insulation with the reflective sheet attached. I have just insulated around the fridge in the motorhome and it made a great difference to the operation of the fridge
Ray
159758
Reply By: res.q.guy - Friday, Mar 10, 2006 at 19:08
Try coolroom manufacturers.
That's where I get my poly. when I need it in Melb.
159769
Reply By: BenSpoon - Friday, Mar 10, 2006 at 19:08
Perhaps worth a bash:
Australasian Insulation Supplies
You may be able to even get some offcuts that size for a 6 pack.
159770
Reply By: Dilligaf - Friday, Mar 10, 2006 at 21:28
You are usually better off using home insulation pink or yellow batts in the cavity as they fit snugly into the cavity and provide closer contact than foam sheets.
Any hardware store has batts and normally if you have a broken pack they will give you a couple free.
159807
Follow Up By: turbopete - Saturday, Mar 11, 2006 at 08:38
i thnk batts will sag/collapse due to the travel movement
414509
Reply By: Member - Wayne M (WA) - Saturday, Mar 11, 2006 at 14:10
Hi Ray,
Clarke Rubber sell sheets of it, they have several stores around
Perth.
regards Wayne
159920
Reply By: fc_holden - Saturday, Mar 11, 2006 at 22:30
If you can get it use polyurthene sheeting, it's insulation properties is alot better the polystrene, 50mm polyurthene is equal to about 75mm polystrene. As to using pink batts you may as
well stuff the cavity with old newspapers for the thermal efficency you will get when it is squashed in to a space (it relies on the air trapped within its fibre to insulate). The only thing to watch when increasing the insulation thickness is moving the thermal balance point (the point within the fridge wall where the outside temperature balances out with the internal fridge) further out to the outside of the fridge and inducing the possibilty of sweating on the outside of the fridge.
160003
