GU Headlights...I want a brighter beam
Submitted: Monday, Mar 13, 2006 at 00:44
Member - Andrew(WA)
What can be done to get a brighter headlight on the GU Patrol for general driving around purposes?
I don't want to get a bigger loom and all that, Just want to know what the best globe type and 'watt' capacity I should go for.
I hear about these 'extra
bright' halogen globes and 'blue' lights. Are they any good and which is the best?
Reply By: Member - Ross H (QLD) - Monday, Mar 13, 2006 at 03:05
Hi andrew
I got a set of bulbs from ARB and they are called fatboys. I have had they ones from repco and super cheap ie. 90/100 and so on but found I was always blowing bulbs. The fat boys are brighter than standard but low beam is very
bright concentrated light they say that is so when you drive with spots on and dip to low you dont get that second or two when your have to adjust to next to no light. I personally find them very good and for the last 2 years have not blown a bulb.
Ther are lots of different bulbs out there and people will have their own opions whether they make a difference or not personally I like to see were I am going.
regards
ross
160171
Reply By: jorgejhandal - Monday, Mar 13, 2006 at 04:29
you can always put in a xenon kit, I put h4 xenon kit with high low xenon, and the h3 foglamps in xenon,
160172
Follow Up By: Member - Andrew(WA) - Monday, Mar 13, 2006 at 19:36
How much $$$ is it worth the result?
415010
Reply By: Rosco - Qld - Monday, Mar 13, 2006 at 09:16
I tried the Philips Blue jobbies and they're quite a bit better than standard.
Rosco
160184
Reply By: Bonz (Vic) - Monday, Mar 13, 2006 at 09:36
There are several "Plus 50" globes around, just take a cruise thru the Autobarn or similar store near you. These use another gas inside the halogen globe to allow the filament to burn brighter=more light. Theyre MUCH better than the marketing gimmickry of the blue lights, in fact if you want a couple of blue ones you can have
mine that I bought tried and took out, they actually throw less light onto the road.
If you do choose to go with a higher wattage like 90/100 I wouldnt do that without installing relays for high and low beam, which is what I ended up doing on our GU. By the way, yoou dont have to replace the whole loom to upgrade, just little bit of wiring at the light end of the loom.
Try the Plus 50's first I reckon.
160187
Follow Up By: flappa - Monday, Mar 13, 2006 at 10:54
Apparently the Phillips PLUS 50's are the pick of these . . .
Haven't got around to changing over myself yet.
414864
Follow Up By: Member - Andrew(WA) - Monday, Mar 13, 2006 at 19:47
Thanks guys....
415018
Follow Up By: Star Bug - Monday, Mar 13, 2006 at 23:50
I must agree. Forget the "Cool Blue" lamps, and go the plus 50's.
All the blurb on the cool blue's was telling me how cool I'd look cruzin' down the street in my machine.
I dont want looks..... I want perfomance
The plus 50's selling point was it gave you a whiter light and more of it, and hence a greater visual range. Great in clear conditions.
There are also an all weather option as
well. A more yellow tint to the light but better penetration of rain and fog.
For $26 a pair of H4 +50 lamps from Coventry's, for Hella or Phillips, it's money
well spent. These are ADR compliant too.
415095
Reply By: Jarrod - Monday, Mar 13, 2006 at 10:19
G'day Andy, Mate, like you, I wanted to upgrade the standard driving around town general purpose low beams.
Found this supplier, he's a wealth of knowledge (no affiliation, just facts) and ended up going for a HID conversion - about $320 from memory, but holy brightness - looks just like a brand new Merc/beamer white "daylight" system. - In all honesty, makes things stand out better. I tried the auto bahn "Blue globes" - I think there a bit of a poor mans try hard HID conversion, and infact think they were worse than the originals. HID draws less current, lasts longer ( Filament/globe burn life), doesn't get anywhere near as hot, ( No wasted energy producing heat like a halogen bulb).
But on the down side, way more exxy to buy, replacement bulbs also quite expensive, Youv've got to install a little ballast type box near each globe.
He also sells all the blue type / higher output bulbs.
Other thing is to check the type of bulb you need. I originally thought
mine would be the old H4 stlye - so rang to order same, guy from
bright lie atuo asks what sort of veh, I tell him 100 series, he says nuh, its 2 sep. bulbs, a 9005 and a 9006....
so there you go.
Jarrod.
OH, here's his www
http://www.brightlightautoparts.com/index.html
160191
Follow Up By: Gu_Patrol - Thursday, Mar 16, 2006 at 18:41
Jarrod have you got all 4 lights with HID's , and is that $320 a pair or for each light,
I'm interested to see if that dealer has the same type of HID's as Xexon0z at @1595 a pair for the H4 HI/Lo setup in which
Roachie has in his GU.
Can either of you guys email me @ reno62@dodo.com.au
415707
Reply By: revhead307 - Monday, Mar 13, 2006 at 10:49
I used to run 130/90's for about 2 years. Didnt have upgraded wiring and would periodically blow a globe.
Bought some Ultra
bright 6000K blue style lights, and hated them...crap on road performance...
The Narva plus 50 style globes do ok.
Rev
160200
Reply By: Utemad - Monday, Mar 13, 2006 at 11:07
Careful fitting higher wattage bulbs to your GU headlights. We had a Narva rep come to our club and he said that you can't fit them to GU's or any other vehicle with polycarbonate headlights as the headlight itself will fail. He showed us headlights that had crazed front clear sections as
well as melted ones.
160203
Follow Up By: Leroy - Tuesday, Mar 14, 2006 at 08:21
ive got an 04 GU and my headlights are glass.
Leroy
415133
Follow Up By: Utemad - Tuesday, Mar 14, 2006 at 12:24
That is interesting. What is the rest of the headlight made of i.e the reflector? Plastic or metal?
He made a point of the GU headlights being unsuitable for a wattage upgade as he was talking to a 4x4 club. However he also showed us some AU? Falcon headlights that had also failed.
415167
Follow Up By: Leroy - Tuesday, Mar 14, 2006 at 14:24
I don't know....prob plastic. I saw a headlight for a navara and it was poly carb.
Years ago in my VH crapolladore I put in 130/90 and it melted the healight insert holder! But I did do a loom upg which helped heaps as all the voltage was switched through a switch with no relay.
Leroy
415205
Follow Up By: Utemad - Tuesday, Mar 14, 2006 at 17:25
Being the inquisitive person that I am. I emailed Nissan spare parts and this is their reply copied below (a very quick reply too).
"polycarbonate outer plastic inner
will it handle more heat ? your guess is as good as ours
we have no way of telling that"
I said I had a 2004 Patrol but I am assuming all GU headlights are the same???
I had a VH Commodore once too. The headlights were really bad so I removed the glass and there was no reflective material left on the inside of the headlights!!! I replaced them both and WOW what a difference :-)
415249
Reply By: phil - Monday, Mar 13, 2006 at 11:24
Hi all,
Don't forget that it is illegal to have a low beam headlight with greater than 55W globes.
Make sure there are no voltage drops in the wiring. These can sometimes be in unexpected
places. I found nearly 0.5v drop from the alternator ground to the body caused by a dodgy earth point. An extra earth wire direct from the alternator to another earth point solved this and my lights are considerably brighter now.
Phil I
160207
Follow Up By: blown4by - Tuesday, Mar 14, 2006 at 21:29
Whereabouts does it say you can't have low beam headlights with greater than 55w globes?
415310
Follow Up By: phil - Thursday, Mar 16, 2006 at 13:21
In the ADRs (Australian Design Rules)
I guess that if you got an engineers certificate it might be possible.
Phil I
415655
Reply By: Member - Kingsley N (SA) - Monday, Mar 13, 2006 at 12:33
I am very happy with the Phillips replacement bulbs that I got at the TJM stand at the last 4WD show. They are much whiter and give excellent illumination. They are a legal standard replacement not requiring new wiring. Changing the bulbs is a little tricky on the LHS if you have a 2nd battery fitted there. ( see my previous post). I went for the white ones on advice from the salesperson.
I changed the bulbs in the original
driving lights too and it made a noticeable improvement. Total cost was about $70.00 for four bulbs.
Kings
160215
Follow Up By: Member - Andrew(WA) - Monday, Mar 13, 2006 at 19:46
Kingsley
What that the Phillips plus 50's in white? as mentioned further up in another reply?
Might give them try...
415017
Follow Up By: Member - Kingsley N (SA) - Tuesday, Mar 14, 2006 at 00:49
Andrew,
Yes definitely Phillips Vision Plus +50% white bulbs. H4 for the mains and H3 for the spots. The Show had a stand set up to show the various light effects and spread.
They are legal replacement for the originals and no loom to worry about. I noticed a big improvement and would not bother with anything else. Good value.
Kings
415104
Reply By: Member - Roachie (SA) - Monday, Mar 13, 2006 at 19:23
I'm happy with my Xenon-Oz set-up, but @ $1500- I guess you'd say I'd wanna be bloody happy, eh?
160269
Reply By: GaryInOz (Vic) - Monday, Mar 13, 2006 at 21:42
Everyone seems to think, "if I haven't got enough light, I'll just fit bigger globes". Unfortunately it doesn't work that way in real life.
Your best and most effective bet WOULD be to upgrade the loom to the headlights. Most looms are built from the factory to be "adequate" for the regulation 55/60 globes that are fitted, and as cheap as they can possibly make them. Putting extra load on them by fitting bigger wattage globes only causes more power to be lost in the loom through resistance for only a marginal increase in brightness.
The top 20-25% of the light's brightness comes from the last 0.5-1 volt, so any improvement by way of reducing resistive losses in the loom is worth it. Having an external loom also means there is no possibility of shorting out something in the main loom through inadvertant overload.
Do the loom first...............
160304
Reply By: Gu_Patrol - Thursday, Mar 16, 2006 at 19:21
160992
