Qualcomm GSP-1600 Sat Phone
Submitted: Tuesday, Mar 14, 2006 at 10:49
ThreadID: 31721 Views:3137 Replies:5 FollowUps:9
Hi Guys,
Does anyone know if you can connect an external CDMA antenna to a Qualcomm GSP-1600 sat phone? You can buy the car kit and it looks like it only has the facility for a sat antenna. Any info would be appreciated!!
Leroy
Reply By: Grumpy in WA - Tuesday, Mar 14, 2006 at 12:56
AFAIK they work on different frequencies so the CDMA antenna won't work for the Sat Phone. The antenna can't radiate efficiently at the frequency of the Sat Phone. But I'm no expert.
AnswerID: 160425
Follow Up By: Leroy - Tuesday, Mar 14, 2006 at 13:24
The Qualcomm GSP-1600 is a Sat and CDMA. The car kit has tails for a sat antenna and cdma antenna. The car kit costs $1700 plus CDMA antenna plus fitting. I was hoping to get an adapter to plug in the cdma antenna.
Leroy
FollowupID: 415192
Reply By: Member - Mike DID - Tuesday, Mar 14, 2006 at 19:42
Do you want to connect the antenna direct to the phone or to the Car Kit ?
Mike
AnswerID: 160492
Follow Up By: Leroy - Tuesday, Mar 14, 2006 at 22:44
Direct to the phone. The car kit costs $1700.
Leroy
FollowupID: 415343
Reply By: Member - Doug T (QLD) - Tuesday, Mar 14, 2006 at 22:27
Try this link for info
antennae
AnswerID: 160550
Follow Up By: Leroy - Tuesday, Mar 14, 2006 at 22:46
There's no product to connect cdma antenna direct to handset.
Leroy
FollowupID: 415345
Follow Up By: Member - Doug T (QLD) - Tuesday, Mar 14, 2006 at 23:04
Leroy
Maybe it's like a GPS they don't have long external antennae's although externals are used as i have 2 but my Garmin Quest can work quite ok from the units built-in antennae
FollowupID: 415351
Follow Up By: Member - Doug T (QLD) - Tuesday, Mar 14, 2006 at 23:07
QUALCOMM GSP1600 ACCESSORIES
Product Rec. Retail Price (incl GST)
GCK1410 Car kit $1,699.00
In-Car Charger $129.00
Battery Travel Pack $329.00
Universal Travel Charger $189.00
Car-Kit Antenna $840.00 ...........................??????
FollowupID: 415352
Follow Up By: Leroy - Wednesday, Mar 15, 2006 at 10:48
'Car-Kit Antenna $840.00 ...........................?????? '
Where did you find the Car-Kit Antenna ? Was it CDMA or Sat?
Leroy
FollowupID: 415429
Follow Up By: Member - Doug T (QLD) - Wednesday, Mar 15, 2006 at 14:35
Leroy
It's all in the URL i posted before but try this one , it will take you direct to the page,
pricing
Doug
FollowupID: 415459
Reply By: Member - Barry C (NT) - Tuesday, Mar 14, 2006 at 23:23
I have used it in the NT and the GSP1600 works well in very remote areas, both in car and stand alone.
One very important point.
Watch out for the "roam" feature that automatically selects CDMA if it detects a CDMA service and you are not signed up for the CDMA service. MY GSP1600 found the CDMA network (and locked onto it) but we had not signed up for the service on the satphone as we have CDMA mobiles for that purpose. So the catch is you get what you sign up for.
When you switch the GSP1600 to manual for satphone service it works very well, so if you have no CDMA service plan ON your satphone leave the satphone on manual satellite ONLY.
Sometimes too many automatic "features" are not desirable. Hope this makes sense as it baffled me until I worked out what the problem was.
Barry
AnswerID: 160565
Follow Up By: Leroy - Wednesday, Mar 15, 2006 at 10:52
thanks for the tip. the phone is signed up for CDMA also so it's not an issue for us.
Leroy
FollowupID: 415431
Reply By: Member - Mike DID - Tuesday, Mar 14, 2006 at 23:34
Can you see any connectors (or rubber plugs covering connectors) that the Vehicle Cradle connects to ?
Is there a large connector at the base that everything connects to ?
Mike
AnswerID: 160566
Follow Up By: Leroy - Wednesday, Mar 15, 2006 at 10:50
Unfortunately I don't have the phone in front of me. I spoke to Telstat and they guy there said that a data cable adapter plugs in the bottom and that it's a pity that they didn't put an antenna skt on there as well!!
Leroy
FollowupID: 415430
