This would be scary
Submitted: Sunday, Mar 19, 2006 at 08:38
Outnabout David (SA)
Was looking at another site and came across this...............scary stuff. Imagine just driving along and the next minute in darkness down a
mine shaft.
Reply By: Outnabout David (SA) - Sunday, Mar 19, 2006 at 08:40
Reply By: Bonz (Vic) - Sunday, Mar 19, 2006 at 08:41
Hi David, that ones done the rounds here mate, but yes it would have been interesting
161457
Reply By: Laura B - Sunday, Mar 19, 2006 at 09:50
its those americans again isnt it!!!
LOL
silly people!!
Laura B
161467
Reply By: Derek from Affordable Batteries & Radiators - Sunday, Mar 19, 2006 at 10:58
Just shows those little Suzuki's will go anywhere.
161475
Reply By: Member - Duncs - Sunday, Mar 19, 2006 at 14:57
It's something to keep in mind.
Not long after moving to
Broken Hill I was out having a look around when I noticed waht looked like the to of a very old ladder sticking up out of the ground. SO I pulled on the handbreak and opened the door to go and have a closer look.
Careful where you put your feet Duncs there is a big hole right beside the car.
The hole was about 600mm diam and of undetermined depth. I could not see the bottom. Probably wouldn't swallow a car but it would be interesting to fall into, with or without the car.
I did check out the ladder and it looked to be an old hand dug mineshaft. It was a bit bigger than the one next to the car but had a bush growing out of the rim and the old ladder to mark it's position so was not a big a worry. The one I was parked next to looked very similar but without the ladder. It was not marked in any way, no discolouring of
the rock no fence nothing. I suspect it was a vent shaft for the
mine under the ladder, which I was not game to decend.
Apparently there are quite a few of these things in the area.
Duncs
161502
Reply By: Member - 'Lucy' - Sunday, Mar 19, 2006 at 22:24
Just some 'woos yanks'
If it happened here, any OZ driver would have just selected reverse and backed it out.
None of this high tech crane c h i t needed.
Just a bunch of girls.
161587
