Too deep?????
Submitted: Wednesday, Mar 22, 2006 at 16:35
Drew - Karratha
How deep is too deep to cross in a 80 Series with a
snorkel, 2" of lift, and twin wheel carriers on the rear bar?? To keep things simple - say on a bitumen floodway with very little current??? 1m? 1.5m? After seeing videos on the news of a couple of 4x4's floating away it has got me wondering when to cross and when to wait....
Drew
Reply By: turbopete - Wednesday, Mar 22, 2006 at 16:43
I do not cross with the family in the car if the
water is any higher than the car body its the pressure against the body and the floatation effect which carries the car away, and many crossings are very slippery
162253
Reply By: Wayne (NSW) - Wednesday, Mar 22, 2006 at 17:12
Drew,
I have had the bonnet of the 80 Series under
water but it was only for a few seconds.
A few things that have to be looked at when doing a
river crossing.
How deep, and remember when you drive through you will cause a bow wave. This will increase the hight of
water on the front of the vehicle.
The vehicle can also float if the
water is deep enough.
How fast is the
water moving, if you can't walk the crossing because the
water is pushing you feet away then it is not possible to drive it.
If the
water is deep and flowing the
water will build up on the side of the vehicle and this can push the vehicle off the causeway.
The other thing is
water coming through the front of the vehicle and catching the blades of the fan and if they flex it could cut a hole in the radiator.
The last thing you have to ask is Do I have to drive this now. Can I go another way or should I wait until the
water level drops.
Wayne
162262
Reply By: Member - Doug T (QLD) - Wednesday, Mar 22, 2006 at 18:55
Everything Wayne has written would be correctm My opinion is different again because i use my 4x4 to make a living so try not to put it at any risk,I won't drive anything over 500 mm of still
water. better to wait 1/2/3 days if need be for
water to lower,better to drive home than catch a bus
162289
Reply By: Member - Davoe (Widgiemooltha) - Wednesday, Mar 22, 2006 at 19:10
I reckon anything over the tyres should be treated with alot of caution. A standard vehicle also has the breathers at about that hight
162294
Follow Up By: Hairy - Wednesday, Mar 22, 2006 at 19:44
Yeh good call, anything over that depends how bad you need to cross.
417000
Reply By: gqpat - Wednesday, Mar 22, 2006 at 20:33
Hi Drew i had a patrol petrol '89' with a two inch lift have put it through rivers with the
water above the bonnet height just had to keep a eye on the current flow this is the main thing i would worry about .
People called me crazy for doing this without a
snorkel,but i just made the intake induction tube face the rear of the engine and it was never a problem..
162323
Reply By: Crackles - Wednesday, Mar 22, 2006 at 21:02
The rule I use is to walk difficult crossings first. If the
water is too fast to stand up it doesn't matter how shallow it is you'd most likely be swept away.
Forgetting for a moment the "should I" & "what preparation" questions the maximum depth a car like yours will ford is between 1 & 1.2 metres deep. Thats around the top of the head lights or up to the door handles (when stationary) in slow moving
water only. When pushing a bow wave this may mean
water breaking over the windscreen!
At this depth it's important to keep the car moving steady as stopping often results in the rear of the car floating & spinning around. (Ivan;-) How much weight you're carrying can be another factor in the car floating particually empty fuel tanks. In very deep
water you should be prepared to open the doors & flood the car to put you back on the bottom in order to regain traction.
But to keep it safe, hub depth when fast flowing, top of the tyres when not.
Cheers Craig...........
HZJ105 Vic.
162334
Reply By: Willem - Wednesday, Mar 22, 2006 at 21:12
I have had
water halfway up the windscreen on a Nissan but only for a very short distance.(Blind and snorkle fitted)
I agree with most of the above posts. Top of the wheel sould be maximum height to cross.
I would do what Doug does, however. Boil the billy and wait till the
water goes down.
162338
