Clunky 60 series steering
Submitted: Thursday, Mar 23, 2006 at 04:09
ThreadID: 32066 Views:3406 Replies:4 FollowUps:4
G'day Folks,
I have a 1986 model 12HT 60 series wagon with adjustable steering. The steering is very clunky. My mechanic says that the intermediate steering shaft needs replacement. This shaft runs from the firewall to the steering box and has two small universal joints at either end that have play in them. Toyota said that on late model 60 series the u-joints can't be replaced so you have to buy the entire shaft ($630-). Does anyone know if an earlier model shaft with replaceable u-joints will fit my adjustable steering. Any advice would be much appreciated.
Ben
Reply By: Member - Doug T (QLD) - Thursday, Mar 23, 2006 at 06:48
I would be trying the 4x4 wreckers for good used part , if your handy at installing it your self can save a lot of dollars
AnswerID: 162406
Reply By: muzzimbidgie - Thursday, Mar 23, 2006 at 16:59
MAAAAATE.
Make sure its not the front springs moving side to side.
AnswerID: 162506
Follow Up By: Member - TPM (SA) - Thursday, Mar 23, 2006 at 18:10
Yeah check the bushes in the spring eyes, if they are poly or worn they can produce loud clunks esp. if wet.
FollowupID: 417241
Follow Up By: Rod E B - Friday, Mar 24, 2006 at 12:46
My 1985 model has the same problem
found it to be the springs moveing
if you steer full lock you can see the springs move
been told there is no safety problem
However , I would like to fix the problem
been told to replace springs
FollowupID: 417400
Follow Up By: muzzimbidgie - Friday, Mar 24, 2006 at 12:59
Nah mate, you don't need to replace the springs. Just get the keepers re-done (which gets done anyway if you get the springs re-set) and this will stop the problem.
Better still, if it is just the springs moving, leave it as it is, and be happy that your driving one of the best forby's ever made.
FollowupID: 417401
Follow Up By: Rod E B - Friday, Mar 24, 2006 at 14:24
Only got 240K on the clock , no rust , been under cover except on trips
a little slow with the caravan and thirsty
can only get $3k for it , can buy a lot of petrol and parts for the change over price
also I love it
FollowupID: 417411
Reply By: 100TD - Thursday, Mar 23, 2006 at 22:23
my mates 84 hj60 has exactly the same problem and we tracked it to the int shaft also dont know what im goin to do about it though!
AnswerID: 162576
Reply By: Tim HJ61 (WA) - Friday, Mar 24, 2006 at 00:10
Ben,
Have you asked the crowd at http://forum.ih8mud.com/ ? There is a forum devoted to 60 series trucks and they're a pretty active mob.
It's not the wheel bearings is it? Mine seem to forever needs adjusting - well, at each service anyways. I'm gonna start doing it myself but need a big tool for the nuts - ummmm, perhaps there's a better way of saying that??
Tim
AnswerID: 162586
