TD42 GQ Nissan Patrol Gearbox
Submitted: Friday, Mar 24, 2006 at 14:04
ThreadID: 32109 Views:4504 Replies:2 FollowUps:2
I've just got my gearbox back from the reconditioners today and there still is a slight bearing sounding noise still coming from it. When I push in the clutch this noise disapears. When it was in the shop they put a new bearing kit through the box. I suspected this noise was the input shaft bearing, and it was pretty tired when they stripped it out. The noise is not as bad as before but still noticible. They reckon its the anti-rattle plate. There were none available in town to replace it with, and they thought is was allright. It is mentioned on the invoice about the slight noise and that they suspect it is the anti-rattle plate. Does anyone agree with what the gearbox reconditioners have diagnosed as the source of the noise or is there anything else that could be causing this problem?
dicko1980
Reply By: Alan H (Narangba QLD) - Friday, Mar 24, 2006 at 16:19
Could be a throwout bearing but I don't know the exact throwout device on a patrol. Was the clutch replaced?
Usually if the gearbox is taken out, it is time to renew the clutch and the throwout bearing.
AnswerID: 162664
Follow Up By: dicko1980 - Friday, Mar 24, 2006 at 20:48
Clutch had been replaced approximately 40,000 and had minimal wear, gearbox reconditioner reckoned that the throw out bearing was fine.
FollowupID: 417464
Follow Up By: dicko1980 - Saturday, Mar 25, 2006 at 05:42
Clutch had been replaced 40 000kms and had minimal wear, Gearbox shop reckon it would be a waste not to put it back in. Throwout bearing was fine.
FollowupID: 417522
Reply By: ACDC - Friday, Mar 24, 2006 at 21:01
Don't be concerned it's normal my patrol's done it for years.
When i fitted a new clutch it made it worse but i used a petrol clutch my 4.2d because it stops all the low down vibration and grawling noise.
AnswerID: 162711
