Kneed It - emergency repairs
Submitted: Saturday, Mar 25, 2006 at 10:05
Member - Norm C (QLD)
Have seen a number of references to Kneed It on other posts about what to carry on remote trips. I am familiar with the stuff and have used it for emergency repairs to
water pipes and tanks on a small farm I had a few years ago. But what else is it good for?
How does it go in the heat for emergency repair to a radiator?
How does it go (ie will it take) with diesel fuel for emergency repairs to a fuel
tank?
Other uses?
Norm C
Reply By: 120scruiser - Saturday, Mar 25, 2006 at 10:56
I have used it on a petrol
tank leak but haven't tried it on diesel.
There is a Kneed It version for damp/wet areas as
162793
Reply By: Member - Doug T (QLD) - Saturday, Mar 25, 2006 at 11:46
Are you married ....................LOL
162797
Follow Up By: Member - Norm C (QLD) - Saturday, Mar 25, 2006 at 12:03
perhaps that version uses batteries
417555
Reply By: Bob Y. - Qld - Saturday, Mar 25, 2006 at 12:21
Norm,
Reckon this would be one of the first things put in the toolkit, if heading off on a trip. CRC make one called "Minute- Mend". Selleys used to make a stuff called "Epoxy Ribbon", which was similar, and nearly as good.
Have used them on radiator, and it lasted for at least 2 years, until we sold the truck. Feel it would work with diesel, but due to diesel's wicking habit, the seal mightn't be 100%.
Have seen similar products used to seal holes in
bore casing, make small tool handles, and seal cracks in fuel lines. Understand you can drill and tap it, to accept a bolt, screw etc.
Hooroo...
162802
Reply By: Kenell - Saturday, Mar 25, 2006 at 16:06
Norm,
I have seen it used on a diesel fuel
tank. It had a gash in it about 8cm long and perhaps 4 or 5 mm wide. We managed to get the vehicle on enough angle to allow the area around the hole to dry. We then applied the u kneed it and allowed it to set onite. We were over 8,000ks from home and about 1,000ks from any help. We put fuel into the
tank and it held without a drip. About a week later we noticed it was losing about a litre a day but that was cheaper than getting it fixed. Once it got home I believe it was patched with more of the same product and I suspect it is still there!!! I put some in my kit as soon as I got home. I sincerely hope the purchase was a waste of money but if I need it I suspect it will be worth it's weight in gold.
Good luck
162833
Reply By: Member - Norm C (QLD) - Saturday, Mar 25, 2006 at 17:08
Thanks guys. Just got back from Bunnings with some Kneed It.
At $13.00 and almost zero size and weight, it is a good investment.
162839
Follow Up By: Member - Mike H (VIC) - Saturday, Mar 25, 2006 at 18:32
G'day Norm,
many years ago ( about 20 ) I punctured the petrol
tank on a Holden along the
Birdsville track. The petrol was pi...ng out.
Wile I was laying unter the car getting soaked SWMBO handed that stuff, I'm sure it was Kneed It down to me after kneeding it. Dropped it into the dirt - bugger ...
I cleaned most of the sand off and worked into the hole. It stopped the leak almost instantly. For good measure I smeared a liberal amount of Silicon sealer over the top of it.
Sold the car about 2 years later and the repair was still 'good as'.
Your question reminds me to get a new lot because ehat I have is now many years old.
Mike
417599
Reply By: Member - Davoe (Widgiemooltha) - Saturday, Mar 25, 2006 at 21:28
Have used it on a diesal
tank when we ripped the pipes out of it. it was actually that aqua kneed it stuff and it worked no worries. i tried fixing a plastic
water jerry with same stuff but didnt work
162890
