Timing belt warning light
Submitted: Saturday, Mar 25, 2006 at 10:31
ThreadID: 32137 Views:2002 Replies:1 FollowUps:3
Does anyone know how to reset the timing belt warning light on a Toyota Hilux 98 after replacing the timing belt? On my 1980 Hilux there is a rubber grommet on the dash screen which you popped out and reset it with a thin pen, where this model doesn’t seem to have this feature
Reply By: 120scruiser - Saturday, Mar 25, 2006 at 10:55
Pull the dash cluster out and remove the globe from the warning light hole and fit it in the hole next to it. Then next time you swap it back.
AnswerID: 162792
Follow Up By: Member - 'Lucy' - Saturday, Mar 25, 2006 at 22:36
Just luv this 'hi-tec' stuff
FollowupID: 417641
Follow Up By: TUF80 - Saturday, Mar 25, 2006 at 22:45
120SCRUISER YOUR RIGHT BY REMOVING THE CLUSTER BUT YOU SWAP THE SCREW OVER ON THE BACK NEXT TO WHERE ITS GOT T BELT WRITTEN
FollowupID: 417643
Follow Up By: 120scruiser - Sunday, Mar 26, 2006 at 11:06
You are correct TUF80. My mistake.
I knew it was something like that.
I don't usually do it as I get my mechanics to do that.
FollowupID: 417695
