Creaky GU Patrol
Submitted: Tuesday, Mar 28, 2006 at 23:41
ThreadID: 32284 Views:2394 Replies:7 FollowUps:4
For ages I've had this creaking/flexing noise coming from what appears to be around the rear doors or possibly around the passenger side rear. I've adjusted doors and even investigated inside the rear tailgate doors but the noise still persists. Its mainly heard when doing acute turns such as out of driveways, when negotiating gutters.
Any ideas.
Thanks,
Dave Mitchell.
Reply By: Member- Rox (WA) - Tuesday, Mar 28, 2006 at 23:51
Sway Bars????
Shockies???
AnswerID: 163561
Follow Up By: David31 - Wednesday, Mar 29, 2006 at 12:44
Thanks mate. That gives me something to work on.
Regards,
Dave Mitchell
FollowupID: 418350
Reply By: Willem - Wednesday, Mar 29, 2006 at 04:54
It may be that your tyres are touching the flares/guards. I had the same problem on the GQ until I had a 50mm lift kit fitted.
AnswerID: 163565
Follow Up By: David31 - Wednesday, Mar 29, 2006 at 12:46
Regards,
Dave Mitchell
FollowupID: 418351
Reply By: Farside - Wednesday, Mar 29, 2006 at 07:55
Dave,
I had a similar thing on my GU. I thought it was the reinforcing plate on the bottom left hand corner of the drive side door window. Did some terrible panel beating to try and fix it, with no success. Turned out to be the lack of lube on the door locks and catches.
Angus
AnswerID: 163582
Regards,
Dave Mitchell
FollowupID: 418352
Reply By: Member - Andrew(WA) - Wednesday, Mar 29, 2006 at 10:31
Have you got a roof rack...make sure your mountings are tight!
AnswerID: 163595
Follow Up By: David31 - Wednesday, Mar 29, 2006 at 12:48
I don't have a roof rack. Thanks for replying however.
Regards,
Dave Mitchell
FollowupID: 418353
Reply By: datto311 - Wednesday, Mar 29, 2006 at 17:00
We had the same problem on our GQ. It was the rear door rubbers. A quick spray with Silicone spray fixed it.
May be worth spraying all of the door rubbers with silicone spray, Could be a cheap fix
Noel
AnswerID: 163678
Reply By: Luke SA - Wednesday, Mar 29, 2006 at 22:38
It could be your body to chassis rubbers my brother had the same prob on GQ
AnswerID: 163758
Reply By: Member - Bware (Tweed Valley) - Wednesday, Mar 29, 2006 at 22:53
Had a squeak in the rear of the 80series which was hard to identify; especially as I found it hard to convince the wife to travel in the cargo area to identify it's source. Through a process of elimination (lubricating the rear seat catches etc) I found it to be the rear barn door locks which I have lubricated with vasoline and it cures the squeaks for about 4 months.
AnswerID: 163765
