Natmap 2003...grrr
Submitted: Thursday, Mar 30, 2006 at 19:37
Footloose
I've installed it, de installed it, configured it, re configured it etc. I've installed it from the CD's, installed it from the diskdrive etc ....in other words I've fiddled till my hair turned
grey (actually that happened when I got married:).
And yes I read the userguide HTML etc ...again and again.
Problem: Can't access any 250 sheets or 250K mosaic. Can access everything else I think.
Probably a silly question but .....
Did that lot of maps actually come on the two disks ?
Reply By: Old Scalyback & denny - Thursday, Mar 30, 2006 at 19:58
goodday footy
YES i have 2 discs cd 1 1;1million scale map
mosiac of aust
landsat satellite image of aust
cd21;2500000 scale map
mosiac of aust
steve
163948
Follow Up By: Footloose - Thursday, Mar 30, 2006 at 20:00
Thanks for that Steve. All I see on CD2 is the reference data text, no image ? Geez I must be thick.
418751
Follow Up By: Old Scalyback & denny - Thursday, Mar 30, 2006 at 20:12
are you using oziexplorer
steve
418752
Follow Up By: Footloose - Thursday, Mar 30, 2006 at 20:18
Steve, normally yes but on this occasion I just wanted to use the raster viewer . SUCCESS. I had the %^&&& thing pointed at the wrong directory, of course. I thought it was looking for a map, it was looking for the mapdata...the text file.
Many thanks for your kind assistance.
418754
Follow Up By: Member - Doug T (QLD) - Thursday, Apr 06, 2006 at 14:48
I have gone back a couple days here ,
well i got
mine in the mail and it works perfect with the raster viewer but i can't get it to work in OziExplorer, I had the old version going ok .what i did was deleted the old version and that was full of map files but this new one has stuff all in it as far as files go , I can only see 8 ecw files in the 1:250.000 folder
420127
Follow Up By: Footloose - Thursday, Apr 06, 2006 at 14:56
Doug,
mine is the 2003 version. If yours is the same, read my success post. You might find that you're looking for maps instead of data.
420131
Follow Up By: Member - Doug T (QLD) - Thursday, Apr 06, 2006 at 16:02
Footloose
No i had the 2003 and just purchased the new from ExplorOz 2005 , I had OziExplorer working fine before but with this new version ,Im lost, It works fine through it's own Raster Viewer but I can't get it to work now in OziExplorer, I guess if i keep trying this and that I'll Nail it sooner or later
420149
Reply By: Member - Phil G (SA) - Thursday, Mar 30, 2006 at 20:28
Fotty,
On disk 1 you'll find the Landsat 7 image at:
D:\Rasters\Satellite-Mosaic\mosaic-cd1
Also on disk 1 you'll find the 1:million image at:
D:\Rasters\1M-Mosaic\mosaic-cd1
On disk 2, you'll find the 250k mosaic map at:
D:\Rasters\250K-Mosaic\mosaic-cd2
Next you'll have to download the .map files on the oziexplorer website:
Go to www.oziexplorer.com and go to the "Australian page". This .exe download file slips the map files into a folder on your hard drive. I then put all maps and calibration files in the same folder in my maps folder in Oziexplorer and it all works
Best of luck.
163963
Follow Up By: Member - Phil G (SA) - Thursday, Mar 30, 2006 at 20:30
Whoops.......I meant to call you "footy" not fotty :-((
418759
Follow Up By: Footloose - Thursday, Apr 06, 2006 at 14:54
I have to confess that I've been called worse. Much, much worse :)
420130
