Oil for trolley jack...
Submitted: Tuesday, Apr 04, 2006 at 18:16
ThreadID: 32522 Views:10163 Replies:4 FollowUps:18
Would anyone happen to know what sort of oil is used in a 1850kg trolley jack?
Reply By: Derek from Affordable Batteries & Radiators - Tuesday, Apr 04, 2006 at 18:26
I use Castrol hydraulic oil 'hi-spin'
AnswerID: 164794
Follow Up By: Russel & Mary - Tuesday, Apr 04, 2006 at 18:30
Yes, hydraulic oil. Auto trans fluid, power steering fluid. Rus.
FollowupID: 419704
Follow Up By: Member - Blue (VIC) - Tuesday, Apr 04, 2006 at 18:31
Hi Derek, do you know any of the other properties? We use several different types of hydraulic fluid at work but we use bleep s...
Thanks mate
FollowupID: 419705
Follow Up By: Exploder - Tuesday, Apr 04, 2006 at 19:05
Bleeps would that F U C H S
FollowupID: 419707
Follow Up By: Member - Blue (VIC) - Tuesday, Apr 04, 2006 at 19:34
Yes Exploder... Damn bleeps...
FollowupID: 419714
Reply By: curlewis - Tuesday, Apr 04, 2006 at 19:36
I use Castrol Hyspin also
AnswerID: 164812
Follow Up By: RosscoH - Tuesday, Apr 04, 2006 at 19:49
Brown slippery stuff, doesn't seem to matter in mine, it still leaks out on the floor.
FollowupID: 419718
Reply By: Val - Tuesday, Apr 04, 2006 at 19:56
I have a product that goes by the imaginative name of "jack oil" made by Jamec-Pen and suitable for "pipe benders, hydraulic presses, porta-power cyclinders and garage and bottle jacks" Got it form Repco so long ago I've forgotten when. Only used it once.
BruceV
AnswerID: 164821
Follow Up By: Member - Blue (VIC) - Tuesday, Apr 04, 2006 at 20:03
There's only one problem with that Bruce, I can't get "jack-oil" for free...
FollowupID: 419723
Reply By: Richard Kovac - Tuesday, Apr 04, 2006 at 22:56
Blue
It's only a trolley jack.
Just use clean engine oil any grade.
Richard
AnswerID: 164883
Follow Up By: Shaker - Tuesday, Apr 04, 2006 at 23:35
Good luck!
FollowupID: 419781
Follow Up By: Richard Kovac - Tuesday, Apr 04, 2006 at 23:42
Why?
FollowupID: 419782
Follow Up By: Shaker - Tuesday, Apr 04, 2006 at 23:53
Because it is totally the wrong type of oil.
FollowupID: 419785
Follow Up By: Richard Kovac - Tuesday, Apr 04, 2006 at 23:56
Again why?
FollowupID: 419788
Follow Up By: Shaker - Wednesday, Apr 05, 2006 at 09:27
Courtesy of Google:
"All hydraulic systems start with oil. Oil is the lifeblood of the beast. Since oil is a liquid it cannot be compressed. That means it will flow and transmit power virtually anywhere. As with any fluid this form of power transmission needs to be channeled and told where to go. In simple terms that is what a hydraulic system does. The oil is the lubricant and vehicle for transmission of this power. Hydraulic oil is not just any oil. It is formulated to withstand a wide variety of temperatures and has additives that control its reaction to the rubber seals and plastic parts found in the components of the system. A wrong oil type can cause o-ring swelling and dissolve seals. Use only hydraulic oil recommended for your application."
An hydraulic jack would work with water, but would you use it?
Using your theory we might as well just put engine oil in everything, engine, gearbox, diff, power steering, auto trans etc etc.
FollowupID: 419833
Follow Up By: Richard Kovac - Wednesday, Apr 05, 2006 at 21:05
Shaker
From my own library
1. Hydraulic power is nearly always generated from mechanical power. Example: A hydraulic pump driven by an engine crankshaft.
2. Hydraulic power output is nearly always achieved by converting back to mechanical energy. Example: A cylinder, which raises a heavy object.
3. There are three types of hydraulic energy:
a) potential or pressure energy
b) kinetic energy, the energy of moving liquids
c) heat energy, the energy of resistance to flow, or friction
4. Hydraulic energy is "neither" created nor destroyed; only converted to another form.
5. All energy put into a hydraulic system must come out either as work (gain) or as heat (loss).
6. When a moving liquid is restricted, heat is created and there is a loss of potential energy (pressure) for doing work. Example: A tube or hose that is too small or is restricted. Orifices and relief valves are also restriction but are purposely designed into the system.
7. Flow through an orifice or restriction causes a pressure drop.
8. Oil must be confined to create pressure for work. A tightly sealed system is a must in hydraulics.
9. Oil takes the course of least resistance.
10. Oil is normally pushed into a pump, not drawn into it. (Atmospheric pressure supplies this push). For this reason, an air vent is needed in the top of the reservoir.
11. A pump does not pump pressure; it creates flow. Pressure is caused by resistance to flow.
12. Two hydraulic systems may produce the same power output, one at high pressure and low flow, and the other at low pressure and high flow.
13. A basic system must include four components: a reservoir to store the oil; a pump to push the oil through the system; valves to control pressure and flow; and a cylinder (or motor) to convert the movement into work.
14. Compare the two major hydraulic systems:
a) Open centre system = pressure is varied but flow is constant.
b) Closed centre system = flow is varied but pressure is constant.
15. There are two basic types of hydraulics:
a) Hydrodynamics is the use of fluid at high speeds "on impact" to supply power. Example: a torque converter.
b) Hydrostatics
Richard Kovac
Service Manager
Gerrard Hydraulics
PH: 08 9455 2344
Mobile Ph: 0408 925 606
Work E-mail: richard@gerrardhydraulics.com.au
It's only a jack!
Case still run engine oil in there skid steer loaders as it save the owner runing two oils
FollowupID: 419959
Follow Up By: Member - Blue (VIC) - Wednesday, Apr 05, 2006 at 21:30
I think I'll just try the first hydraulic fluid I find at work... Not, Richard, because I doubt that engine oil will work, just because I can get the hydro for free... Sound like a tight-arse don't I...??? I just don't believe in paying when something can be had for nicks...
FollowupID: 419965
Follow Up By: Richard Kovac - Wednesday, Apr 05, 2006 at 22:07
That's Cool Blue
Fee Oil is good oil "LOL"
Richard
FollowupID: 419980
Follow Up By: Shaker - Thursday, Apr 06, 2006 at 00:01
Hmmmm ....... So, jack manufacturers use engine oil?
I know years ago BMC (later Leyland) had torque converters that ran in engine oil, but it is very uncommon.
FollowupID: 420005
Follow Up By: Richard Kovac - Thursday, Apr 06, 2006 at 11:25
Shaker
"Using your theory we might as well just put engine oil in everything, engine, gearbox, diff, power steering, auto trans etc etc."
"Hmmmm ....... So, jack manufacturers use engine oil?"
These are your assumptions
Not mine
I could go on for ever
And quote a lot of Technical Information if you wont, none of it's not mine!!!
Richard
FollowupID: 420054
Follow Up By: Shaker - Thursday, Apr 06, 2006 at 12:32
Sorry for any misunderstanding, but I thought it was you that said .............
"Blue
Richard "
FollowupID: 420075
Follow Up By: Richard Kovac - Thursday, Apr 06, 2006 at 22:07
Shaker
you are right
Richard
I didn't say
FollowupID: 420283
