Ginger beer, Ginger beer,Ginger beer and 1 other yer soaks
Submitted: Friday, Apr 07, 2006 at 21:06
ThreadID: 32658 Views:7657 Replies:6 FollowUps:3
Ginger Beer
This recipe makes three 1.25 litre bottles of ginger beer, which is ready to drink in about 4 days from first making - depending on the temperature. As live yeast is used for the brewing, the temperature needs to be at least 20C for the yeast to work.
In a large plastic container, mix together:
• 5 pints of cold water
• 1 and 1/2 cups of sugar
• 1/2 teaspoon of active dry yeast
• 1 large heaped teaspoon of powdered ginger
• 1 teaspoon cream of tartar
• 1/4 teaspoon of tartaric acid
• Grated rind and juice of one lemon
Leave stand for at least 12 hours. (I have discovered it can be left for longer as there are times when 12 hours later simply isn't convenient!)
Strain through muslin, and bottle in well sealed, strong bottles. The PET softdrink bottles are quite good, as they are easy to gauge the readiness of the beer in. The plastic bottle will be soft and easy to deform when first filled, but after a day or two of warm weather, the bottle will feel extremely tight. Then it is time to put the beer in the fridge! (Make sure you leave an air gap of at least 2cm below the bottle neck when filling the bottles).
Be sure to open the bottles with care when ready to drink the beer, as it can fizz up to the extent that you get ginger beer everywhere but in your glass. With really fizzy bottles, it is not difficult to undo the screw top just enough to relieve the pressure in the bottle without the fiz rising, and leave it like that for some minutes. The secret to success is patience. After a while you get a feel for whether the fiz is going to be faster than you can pour the beer!
The science behind this recipe
The science is simple. Yeast cells use the sugar as their energy source, in the process converting the sugar to alcohol and carbon dioxide. (The yeast cells multiply at an ernormous rate during this process, as they reproduce via cell division). When the beer is sealed in the bottles, the carbon dioxide builds up in the air gap above the liquid, and remains dissolved in the liquid. The greater the pressure in the bottle due to gas build up, the more carbon dioxide remains dissolved in the beer. When the bottle is opened and the pressure relieved, the dissolved carbon dioxide starts to come out of solution, hence causing the bubbles and the fizzing of the beer.
Happy drinking
Ginger Beer
Fresh ginger but for ginger beer, powdered is better
Chef: Amanda Conrad
A refreshing drink for any time of the year
You need:
50g fresh bakers yeast
300ml water
2tsp ground ginger
2tsp sugar
Method:
Start a Ginger Beer plant by placing 50g of fresh bakers yeast in a jar with about 300ml of water, 2 teaspoons of ground ginger and 2 teaspoons of sugar.
Feed the plant each day for the next 7 days by adding one teaspoon of sugar and one teaspoon of ground ginger.
Strain the mixture through fine muslin (keep the sediment) and reserve the liquid. Dissolve 450g of sugar in 600ml of boiling water. When cool, add the juice of two lemons and the reserved liquid and make up the volume to 4½ litres.
Bottle, keep for one week, then, either drink quickly or keep refrigerated as it tends to become livelier with age.
Restart the plant by dividing the sediment into two parts and placing each half into a jar with 300ml of water. You now have two plants to feed as above. If one plant is enough, give one away
This recipe was featured by Katie Smith
Date published: 23/3/2002
ABC Hobart | Recipe Index | Recipe
Irish Cream liqueur
Chef: Amanda Conrad
You need:
Vanilla Essence ¼ teaspoonful
3 Eggs
Condensed Milk 1 tin
Whisky 1 cup
Thickened Cream 1 cup
Chocolate Topping 1½ tablespoonfuls
Coconut Essence ¾ teaspoonful
Method:
Put into a blender and mix all together.
This recipe was featured by Trevor Jackson on Home Brewing Talkback
Date published: 5/8/2002
Home-made ginger beer
Chef: Sally Wise
It always fascinated me as a kid that you could grow a living, breathing ginger beer plant by simply mixing up ground ginger, sugar, yeast and water. Here's Sally Wise's take on the topic.
You need:
Yeast, ground ginger, sugar, water.
Plant:
• ½ teaspoon dried yeast
• 1 rounded teaspoon ground ginger
• 1 rounded teaspoon sugar
• 1 cup lukewarm water
Method:
Mix all together in a jar, cover with a piece of muslin and secure with a rubber band.
Each day for the next week, add 1 teaspoon sugar and 1 teaspoon ground ginger.
The plant: Divide the plant left in the muslin into two halves. Place one of these in a glass jar with a cup of warm water. Then next day start feeding as before, that is, one teaspoon of ginger and one of sugar each day. The other half of the plant can be discarded, or you can have two plants 'on the go'.
To make up the Ginger Beer:
For the syrup, mix together:
• 4 cups of sugar
• 24 cups of warm water
• ½ cup strained lemon juice
then:
Strain the ginger beer plant through two layers of muslin.
Pour the resulting liquid into the syrup and mix well.
Bottle and seal. The ginger beer should be ready to drink by the end of a week.
Homemade Ginger Beer
Serving size: unspecified
Cooking time: Quick with advance preparation
Makes 2 litres.
INGREDIENTS
1 cup warm water
3 teaspoons instant yeast
1 tablespoon dried ginger
1¼ cups caster sugar
juice of a lemon
ice and lemon slices to serve
METHOD
Combine water, yeast, ginger, and ¼ cup of the sugar in a jug. Stir well to dissolve the yeast and sugar. Allow to stand in a warm place for 10-15 minutes or until beginning to froth.
Add remaining sugar and lemon juice. Stir well. Pour into 2 x 1 litre plastic bottles. Add enough tepid water to nearly fill. Stand at room temperature for 4 to 12 hours, or until the bottles become 'un-dentable' when pressed. Refrigerate until desired.
Serve chilled with ice and lemon slices.
HOME BREWED CHRISTMAS
FROM COOPERS
The whole family will be able to enjoy a home brewed Christmas this year, thanks to Coopers
Brewery.
The world’s largest producer of home brew concentrates has released a new non-alcoholic ginger
beer for children as well as its flagship Pale Ale for the adults of the family.
Coopers National Sales and Export Manager of Brewing Products, Mr Scott Harris, said home
brew kits were traditionally a popular gift at Christmas time.
“The addition of ginger beer to our range of concentrates means that home brewers can now brew
for the whole family, ” he said.
“Home made ginger beer for many people used to be about maintaining messy ginger beer plants,
exploding bottles and inconsistent results.
“However the new Coopers home brew ginger beer concentrate is designed to be brewed in a
Coopers Micro Brew kit, which virtually ensures success every time while eliminating mess. At the
same time, the PET plastic bottles provided in the Coopers Micro Brew kits are ideal for bottling
ginger beer.
“It is the first time we have entered the ginger beer market and we were conscious of the need to
provide a non-alcoholic option for families with younger children.
“Our concentrate produces about 20 litres of traditionally flavoured ginger beer with a hint of spice
and plenty of bite, which will appeal to people who like their ginger beer with tang.”
Mr Harris said adults also had the option of producing an alcoholic ginger beer using the same
concentrate.
Coopers Pale Ale concentrate is part of the International Series range sold through major
supermarket chains and retailers across Australia.
Mr Harris, said that because Coopers Pale Ale had such a strong following, the brewery had been
careful to ensure that the concentrate produced a beer as close as possible to the bottled product.
“Coopers brewers spent a considerable amount of time experimenting with different yeasts,
concentrates and brewing sugars to get it right,” he said.
“The selected dry yeast blend produces the fruity esters and clean finish that Pale Ale drinker
enjoy. The concentrate has been designed specifically for use with Coopers Brew Enhancer 2 to
achieve the mouthfeel and creamy head associated with our Pale Ale.”
Coopers Micro Brew Kits comprise a fermenter, PET bottles, seals, a can of concentrate and
everything else required to produce 23 litres of high quality beer, including an instruction booklet
and an video. Back up and troubleshooting are available on the special home brew hotline or via e-
mail.
“At a cost of about 42 cents for a 750 ml bottle, home brewed beer can certainly provide significant
savings to the family budget,” Mr Harris said.
Normally priced at around $70, the kits are available from most major discount stores and
supermarkets.
Coopers is the world’s largest producer of home brew concentrates and currently has 17 different
beer styles to choose from.
Grrr!!!
Reply By: Member - Omaroo (NSW) - Friday, Apr 07, 2006 at 21:08
YOU BEEEAUTY!!!!!!
AnswerID: 165671
Reply By: Member - JohnR (Vic)&Moses - Friday, Apr 07, 2006 at 22:21
Good on yer Crazy Dog. I was sent to a boarding school for my sins and in my last year with another guy we made our own. Some of you would remember the screw top Marchants bottles with the internal screw and heavy construction bottles. Unfortunately the dozen or so we made of the first batch, four of them flavoured the clothes in the wardrobe storage. We otherwise enjoyed the remaining ones. They were from the ginger beer plant system.
AnswerID: 165690
Follow Up By: Member - Crazy Dog (QLD) - Saturday, Apr 08, 2006 at 01:10
Been a long time - refereing to the internal ...scr..!
Grrr!!!
FollowupID: 420593
Follow Up By: Jimbo - Saturday, Apr 08, 2006 at 07:33
John,
Same as we did with the old Marchants bottles.
Sparklarklarkling.
FollowupID: 420632
Reply By: Member - TPM (SA) - Friday, Apr 07, 2006 at 23:17
Ive been banned on making this stuff, The better 3/4 didnt appreciate pulling glass shards out of plasterboard in the pantry while I was away. Oops !
I now use the Coopers Ginger beer brew in old plastic coke 750 ml bottles
Its "hiding" in the shed " Insert evil laugh here.........HA HA HA HA HA HA....
AnswerID: 165708
Reply By: revhead307 - Friday, Apr 07, 2006 at 23:44
I was actually drinking some homebrew ginger beer tonight.
have used the commercial stuff, not bad but too sweet and not enough flavour...
but now i make my own from scratch...using a combo of fresh and powdered ginger, Dextrose to ferment, Maltodextrose (imparts sweetness without fermenting), brewers yeast etc.
am experimenting with adding some hops to take the edge off and leave some residual bitterness.
very refreshing...and I often make it that little bit too strong on purpose lol
Rev
AnswerID: 165713
Reply By: bombsquad - Saturday, Apr 08, 2006 at 00:18
I also found the Coopers and Brewster premix a bit sweet - but a shot of rum per stubbie at bottling solved that..hic..
cheeers andrew
AnswerID: 165715
Reply By: Member - Prickle (SA) - Sunday, Apr 09, 2006 at 21:28
Thanks for the recipes, have dropped them into my HB file.
When I have time will have a good read.
If you are interested in a good stout recipe will post or send this to you. Is better than Guiness.
I reckon
Russ
Life-often hell but never boring.
AnswerID: 166050
Follow Up By: Member - Crazy Dog (QLD) - Sunday, Apr 09, 2006 at 22:24
Pleaze thru members contacts ta!
Lance
FollowupID: 420991
