installing driving lights for jeep cherokee
Submitted: Saturday, Apr 08, 2006 at 08:31
ThreadID: 32669 Views:2314 Replies:2 FollowUps:2
hi. just wondering if anyone has installed spotties on a 2005 kj cherokee? I'm having trouble finding a spot to feed the wire from the engine bay into the cab and I dont really want to drill a hole. Any help would be appreciated.
Reply By: Member - 'Lucy' - Saturday, Apr 08, 2006 at 14:29
Simmo
I have an 05 KJ CRD and recently installed a brake controller.
On the passenger side fire wall is a large rubber grommet with a multi wired loom going through it.
Just use a sharp thingy (your choice) to pierce a hole in the said grommet about 5-10mm from the loom insertion.
Give the cable/s you want to insert/pass through a liberal coating of lacum powder and they will slip through easily.
You can then conduit them and run behind the top of the carpet in the left hand footwell, under the heat area and where ever you like there after.
All totally invisible
Have a good one
AnswerID: 165795
Follow Up By: simmo1 - Wednesday, Apr 26, 2006 at 22:30
Sorry for the delay to respond, been away for work. Anyway thanks for your advice, will go looking for the grommet. Thanks
FollowupID: 424561
Reply By: Member - Omaroo (NSW) - Saturday, Apr 08, 2006 at 14:56
Simmo - go to the dedicated Jeep website and ask there. They are a very helpful bunch!
www.ausjeepoffroad.com/forum/index.php
Then go to the "Cherokee Drivers" forum.
Chris
AnswerID: 165801
Follow Up By: simmo1 - Wednesday, Apr 26, 2006 at 22:31
Thanks, will go and check the site.
FollowupID: 424562
