Hayman Reese Tow hitch adjustment
Submitted: Saturday, Apr 22, 2006 at 13:32
cobes
Hi all,
Just wondering if it is legal or advisable to insert your hitch upside down to obtain a higher towing hitch level?
Chris.
Reply By: Member - TonyG (Qld) - Saturday, Apr 22, 2006 at 13:46
Hi Cobes,
I don't see why it would be illiegal.
I have done exactly the same thing to allow my trailer to sit level with the car
TonyG
168459
Reply By: Member - Nick (Kununurra) - Saturday, Apr 22, 2006 at 14:31
Yep,we fit ours which ever way levels the trailer we're towing.
168460
Reply By: V8Diesel - Saturday, Apr 22, 2006 at 14:57
Wouldn't all your stuff fall out of the trailer?
168462
Follow Up By: Mr Fawlty - Saturday, Apr 22, 2006 at 15:06
I think he means turn just the tounge over ... not the whole trailer....PMSL Its NOT FRIDAY... HUMOUR IS ONLY ALLOWED ON FRIDAY....
423790
Follow Up By: OLDMAGPIE - Saturday, Apr 22, 2006 at 16:32
no but you'd need bigger
wheels ha cheers
423796
Reply By: shepo - Saturday, Apr 22, 2006 at 16:36
hi cobes, iam sure it can be done legally but it has a lower load carrying ability good luck
168467
Follow Up By: turbopete - Saturday, Apr 22, 2006 at 17:07
"but it has a lower load carring ability" Now i know the load is lower cause i turned the tongue over so how does that effect the load carrying ability is still joking hahahahahah
423804
Reply By: Alloy c/t - Saturday, Apr 22, 2006 at 17:10
In our Toyota Cruiser handbook 2 towing weights are given , bar upermost allows 2500kg ,bar upside down allows only 750kg ..has to do with angle of weld vs strain ,,seem to remember that Ford had a major recall of their factory fit hayman hitches inserts a few years ago about stress fractures caused by overload when insert upside down /rightway up.
168472
Follow Up By: Kiwi Kia - Saturday, Apr 22, 2006 at 18:18
Well, thats interesting !
I can't see why the angle should be so critical. Going over bumps, crossing footpaths etc. even just bouncing around on a rough road will constantly change the hitch angle. Different makes of vehicles have different hitch heights anyway.
The reciever welds do not change and the tongue is usually either a straight one piece box section or a heavy bit of flat metal with a couple of bends (swan neck) welded onto a straight box section.
Anyone else got a comment on Ford's difference in towing weights ?
423818
Reply By: Muddy doe (SA) - Saturday, Apr 22, 2006 at 19:00
Just went and got the Toyota tow tongue from the Prado.
It has a label that shows Max Braked 2500kg Max unbraked 750kg. It then has a picture of the tongue with ball in both positions (trying to keep it clean here!) with a max downward ball weight if 250kg in each case. Nowhere does it mention any difference in capacity if you invert the tongue to change the ball height.
Muddy
168482
Reply By: roofscooter2 - Saturday, Apr 22, 2006 at 19:25
Hi Cobes & all other's , i have a motor home & had to get towbar specialy certified & the Certifier told me to use the tongue either way but said naught about it reducing the towing weight or any thing else, Bob.
168488
Reply By: cobes - Saturday, Apr 22, 2006 at 22:51
Hi all thanks for all of your comments.
I didn't think that there would be a problem although i now feel more comfortable after all of your feedback and comments.
Thanks to all who responded to my question.
Chris.
168516
Reply By: Geoff M (Newcastle, NSW) - Monday, Apr 24, 2006 at 18:11
Hi Cobes,
Don't know if it's legal but hey here's another thing you can do after you turn the Hayman Reece tongue upside down. Make a 7 wheeled vehicle!!
Geoff.
| Geoff,
168737
