new diff lock - new oil leak??
Submitted: Sunday, Apr 23, 2006 at 20:08
ThreadID: 33177 Views:2784 Replies:3 FollowUps:2
hi everyone,
just got a rear air locker installed guys, and noticed a fairly decent run of diff oil through the drum. It's obviously going back, but I take it it's the diff seal?? Maybe it's normal??
The rear bearings weren't replaced I was told.
A massive pain in the bum (including the wallet, lol). I guess it pays to never take your car to get repaired on a friday.
thanks for any ideas.
Reply By: Bonz (Vic) - Sunday, Apr 23, 2006 at 20:11
could be the main diff seal orlso
AnswerID: 168631
Reply By: Rock Crawler - Sunday, Apr 23, 2006 at 20:17
well you have to take out the axles to remove your diff center, usuallu a good idea to change axle seals when doing so . I dosnt take much to get a axle seal leak from removing axles
AnswerID: 168636
Follow Up By: conman - Sunday, Apr 23, 2006 at 20:21
Hi eric,
They should of replaced these yes? If they didn't then they got damaged when it was all put back together. Not to mention the handbrake doesn't work :-))
FollowupID: 424000
Follow Up By: Rock Crawler - Sunday, Apr 23, 2006 at 20:30
I dont know what car you have , but if the hand brake shoes are in the rear disc like a cruiser , then the diff oil will defenentry stuff that up. There is no need to change seals in a locker fit , it's just something I do whenever I remove axles . Seals are under $5 each , so I figure to replace them since i have the axle out .
It could be leaking because they were ruff in fitting axles , it could be just bad luck. Sometimes you can be gental as anything and still manage to stuff the seal up.
FollowupID: 424001
Reply By: Member - Vincent A M (NSW) - Tuesday, Apr 25, 2006 at 09:11
where was it done
AnswerID: 168851
