Truckster/rollerdraws
Submitted: Monday, Feb 10, 2003 at 23:29
ThreadID: 3324 Views:2167 Replies:2 FollowUps:9
Truckster have see your web page very helpfull with the red desert roller draws and home made fridge slide. Can the fridge slide, slide out with the draw stillpushed in? Also each side has 4 berings on the botom and 2 on top as the normal draws is this so?
Reply By: Truckster - Tuesday, Feb 11, 2003 at 09:33
Yes the draw can stay shut. Depends also on how you set it up. Theres about 1 inch from the top of the end of the draw to the top shelf.
The bearings were the most expensive part of the modification! Yea you can use 6 bearings if you like.... More stable, theres a lot of weight in them fridges.
AnswerID: 12865
Follow Up By: Member - Peter- Tuesday, Feb 11, 2003 at 11:07
Truckster Great web site thanks Peter
FollowupID: 7502
Follow Up By: Truckster - Tuesday, Feb 11, 2003 at 18:03
Thanks Peter..
its getting there..... :P
FollowupID: 7538
Follow Up By: Member - Glenn- Tuesday, Feb 11, 2003 at 23:07
Truckster, did you have problems getting the drawers to run parallel? My father bought the Red Desert drawers for his 100 series and they do not sit straight and true. No matter how many ways we have tried to get the sides to be parallel we have had no luck. Gives me the @#$!s as they are a nice looking drawer for a great price. Do you have any advice?
FollowupID: 7559
Follow Up By: Truckster - Tuesday, Feb 11, 2003 at 23:12
Call them and tell them the sides are warped, they will replace them!
There are Red Desert kits out there with missing parts so they have plenty of spares on hand.
Apart from that, loosen it all off, and just bit moire than finger tight so you can just move things, and then try to get them to go smooth..... then tighten up..
mine worked instantly!
FollowupID: 7560
Follow Up By: Member - Glenn- Tuesday, Feb 11, 2003 at 23:21
Thanks Truckster,
They were purchased through a supplier who were bankrupt. They were delivered to L&S Electrics (I think) and the wrong parts were sent initially. There were two sets of holes in support bars (to suit an 80 series) but I have tried everything and nothing seems to work. Dad isn't fussed (of course) but I am. Thanks for the advice, I'll give it a try.
FollowupID: 7562
Follow Up By: Truckster - Tuesday, Feb 11, 2003 at 23:24
Glenn
Mine are Red Desert, and I know others who have called and got spares out of them. I know the story behind them... search the archive here for the 1300 # and call it... they have spares. Red desert still have the spares.
The second set of holes are to make it into a fridge slide.. look at the pics on my site.
My Place
FollowupID: 7563
Follow Up By: Member - Glenn- Tuesday, Feb 11, 2003 at 23:29
Cheers Truckster
Hope to see you on the tracks one day.
FollowupID: 7565
Follow Up By: Rox - Wednesday, Feb 12, 2003 at 20:13
Truckster were did your mate get his bearings from? My best price so far in Perth is $52.14 for 12 of them
FollowupID: 7609
Reply By: Member - Melissa - Tuesday, Feb 11, 2003 at 13:10
Hi Truckster,
What's your URL?
:o) Melissa
AnswerID: 12883
For the beautiful melissa.....
Trucksters Place
FollowupID: 7537
