AnswerID: 170091 Submitted: Monday, May 01, 2006 at 19:33
awill4x4
replied:
Wayne for a start Mig welding is fine, the diffs are all welded by the Mig process from new anyway. Whether your Mig has enough power I don't know as you didn't tell us what machine you used. Are you using a Mig with shielding gas or are you using gasless wire, if gasless wire I think you will be pushing the proverbial shiat uphill.
For a start I would find the ends of the cracks and drill a small hole at either end, 4mm diameter will be fine. When a crack is present it will lengthen as you weld it and you won't even know and although you may have ground out the crack it will continue moving past the ground out area. When a hole is drilled the crack will stop there.
Between the drilled holes then grind a groove and then wire brush and clean out the groove. Unfortunately diff oil is a terrible contaminant and you must really try to remove it so wipe the groove down with lots of Acetone or Methylated Spirits. Some guys like thinners but I find it leaves an oily residue which can contaminate a weld. When you've used the Acetone/Metho and it the welds are overhead it can pay to use compressed air to blow any residual out of the groove prior to welding.
Depending on whether you are working overhead it pays to put in a hot and fast sealing weld then wire brush back and then a capping run to finish off.
One thing to remember is the welders mantra "clean, clean and clean again" I can't over emphasise this point.
Hope this helps. Regards Andrew.
Reply 8 of 13
