Sqeaky rear doors on the GU
Submitted: Tuesday, May 02, 2006 at 12:55
ThreadID: 33452 Views:1809 Replies:6 FollowUps:2
my barn doors have started sqeaking. Even in normal driving conditions..little bump...little sqeak! Big bump...bigger sqeak!
Sounds like the door seals rubbing to me. I have checked the tightness of the doors in the closed position and they seem OK.
Any ideas on how to fix it??? Is there a spray like WD40 that won't stink the car out??
Reply By: Member - Heinz- Tuesday, May 02, 2006 at 13:33
Hi, Andrew
Sometimes I have the same problem with my Troopie.
I tried all sorts of things like adjusting the doors and lubricating hinges,
but that didn't work. Then finaly I ludricated the door locking devices
on the top and bottom of the door and the problem was solved.
Last week I did this again and the noise is gone for the next couple of months.
Good luck.
cheers: Heinz
AnswerID: 170217
Follow Up By: Member - Andrew(WA) - Tuesday, May 02, 2006 at 13:36
Thanks Heinz
What lube do you use?
FollowupID: 425569
Follow Up By: GUPatrol - Tuesday, May 02, 2006 at 16:29
Andrew,
The GU barn door locks have some plastic and rubber bits which in the long term could be damaged by the spraying of CRC or petroleum based lubricants.
I found that the noise comes from the rubber pads which are supposed to hold everything tight.
I lubricate everything with either vaseline, spary on vaseline or rubber grease (PBR or similar) which you should find in brake shops (used to assemble brake calipers etc).
That way you are guaranteed to lubricate but not damage the rubber bits.
Will
FollowupID: 425602
Reply By: Farside - Tuesday, May 02, 2006 at 14:17
I use spray on grease from Autobarn on my door locks to stop the squeek in my GU.
Angus
AnswerID: 170221
Reply By: Member - Heinz- Tuesday, May 02, 2006 at 14:46
Andrew,
I use just CRC out of the spray-can and it works fine.
You need only a little of it, so it's not messy.
This will loosen-up the locking catch.
The catch is not fully closing because of dirt and that is the problem.
Cheers; Heinz
AnswerID: 170224
Reply By: Brew69(SA) - Tuesday, May 02, 2006 at 17:06
Hi Andrew, you can try this i found it to work on my squeaky doors it is Dri Lube it is a solid lubrication in stick form available from all auto shops. Hope it helps Brew
AnswerID: 170253
Reply By: Patrol22 - Wednesday, May 03, 2006 at 13:09
Andrew - I've used various products but have found Lanotec to be the best. Keeps the squeaks down, the hinges and guide lubed and flushes out the dust. Great products @ about $10 a can.
AnswerID: 170418
Reply By: Ronnie - Wednesday, May 03, 2006 at 18:56
I have just fixed mine by adjusting the doors to close a fraction more.
Regards Ronnie
AnswerID: 170505
