Torque wrench settings for 4Runner diesel
Submitted: Wednesday, Feb 12, 2003 at 21:39
ThreadID: 3348 Views:9564 Replies:10 FollowUps:6
Hi everyone,
I asked about this a while ago but didn't win, so am having another go - anyone out there got the torque wrench settings for putting a 2.8 l toyota diesel (3L) back together? Have emailed Toyota and got no response, and I'm a long long way from anywhere I can buy a manual!
Thanks, Tim Z
Reply By: desert - Thursday, Feb 13, 2003 at 13:39
zigglemeister you are testing my memory here! Lets see...... last one I did was a head gasket and I took them down in short steps, ie 60ft/lbs then 80 ft/lbs. Then, turn each stud 90 degrees (1/4 turn) more. Can't help you on the bottom end though.
AnswerID: 13036
Follow Up By: Zigglemeister - Thursday, Feb 13, 2003 at 17:33
Thanks desert,
One down, a few to go... I need just about everything, the motor is completely in bits. Hopefully someone'll have a 2.8 manual somewhere!
FollowupID: 7639
Reply By: Trekker - Thursday, Feb 13, 2003 at 17:11
Tim,
I have a "Gregory's" for the 2.4 L diesels which has the torque wrench settings. If these will help let me know & I'll pass the info on to you.
AnswerID: 13055
Follow Up By: Zigglemeister - Thursday, Feb 13, 2003 at 17:36
Thanks Trekker,
I'll keep hanging on in the hope that someone's got the settings for a 2.8 litre, because they are a bit different, but if I don't get anywhere I'll get back to you - the settings for a 2.4 will probably be a lot closer than what I'd make up out of my head!
Tim Z
FollowupID: 7640
Reply By: Member - Robert- Saturday, Feb 15, 2003 at 10:30
torque is 58lb = 90 degrees = 90 degress
AnswerID: 13188
Reply By: Member - Robert- Saturday, Feb 15, 2003 at 10:31
58lb + 90degrees + 90 degrees
AnswerID: 13189
Reply By: Member - Robert- Saturday, Feb 15, 2003 at 10:33
58lb + 90degrees + 90 degrees you must use new head bolts when ever you remove the head
AnswerID: 13190
Follow Up By: Zigglemeister - Saturday, Feb 15, 2003 at 12:09
Thanks for that Robert,
Got anything on big-end & main brgs, and camshaft mountings?
Regards, Tim Z
FollowupID: 7726
Reply By: Member - Robert- Saturday, Feb 15, 2003 at 19:29
will get the rest on monday for you
AnswerID: 13211
Reply By: Member - Robert- Saturday, Feb 15, 2003 at 19:30
will get the rest on monday for you from work
AnswerID: 13212
Follow Up By: Zigglemeister - Saturday, Feb 15, 2003 at 20:24
Thanks, Much appreciated!
Tim
FollowupID: 7735
Reply By: Member - Robert- Monday, Feb 17, 2003 at 20:58
head 58lb +90degrees + 90 degrees
mains 76lb
conrods 40lb +90dregres
flywheel 90lb
inject pump 47lb
camshaft 72lb
front pulley 125lb
the timing mark for the cam is at 6 oclock you will see a arrow on the back plate line the dot to the arrow
the timing mark for the injector pump is at 12 oclock you will se a mark on the cover line the mark on the gear to it
the timing make for crank is at 12 oclock
when bolting pump to the front timing cover the holes are slotted you have to line the two lines up to get the pump timing right
AnswerID: 13345
Follow Up By: Zigglemeister - Tuesday, Feb 18, 2003 at 07:45
Robert, you are a legend. Thanks very much indeed! If you're ever in Vanuatu for a holiday, make sure you come down to Tanna and say hello!
Tim
FollowupID: 7852
Reply By: Member - Robert- Tuesday, Feb 18, 2003 at 20:40
thanks but where ar you
AnswerID: 13419
Follow Up By: Zigglemeister - Tuesday, Feb 18, 2003 at 21:17
Loananupu village
West Tanna
Vanuatu (used to be known as the New Hebrides)
South Pacific
A long long way from anywhere. Tanna is one of the southernmost islands in the archipelago that is Vanuatu. It is better known than some of the other outer islands on account of the volcano - world's most accessible, you can walk up to the top and look down. Look on a world map, due east of Townsville.
FollowupID: 7875
Reply By: Member - Robert- Tuesday, Feb 18, 2003 at 22:06
ok im in perth western austraila glad i could help
AnswerID: 13427
