Camper Trailer Axle
Submitted: Thursday, May 04, 2006 at 16:34
ThreadID: 33527 Views:2476 Replies:2 FollowUps:3
G'DAy All.
We are planning a trip to the GRR in Oct 06, and I came across an articale in a 4WD magazine a few weeks ago about a replacement stubb axle that slides over the broken section of axle, then clampes on, the hub & bearings can then be installed onto the new stubb axle (once you have found the run away wheel). Doe's anyone know were I can find these replacement stubb axles, as I cannot find the articale again!! I think they were made here in W.A. Any help with this will be greatly appreciated.
Thanks,
Howard.
Reply By: bombsquad - Thursday, May 04, 2006 at 16:47
Not sure about the stub axels you are talking about, but I have a spare with a couple of u bolts that can go on the side of the current axel. This stub also seconds as a spare wheel carrier and big jockey wheel
Cheers Andrew
AnswerID: 170672
Follow Up By: Member - Howard P (WA) - Thursday, May 04, 2006 at 18:04
Andrew,
The stub axle is a square tube with stub attached to the end of it, and it slides over the origonal square axle shaft, and is secured by 2 x bolts through the tube onto the broken axle shaft.
Howard.
FollowupID: 426142
Follow Up By: Member - Jerry C (WA) - Thursday, May 04, 2006 at 22:44
Hi Andrew,
Probably any of the 4B accessory shops, or Trailer Parts Pty Ltd.
Good luck, Jerry
FollowupID: 426225
Follow Up By: Member - Jerry C (WA) - Thursday, May 04, 2006 at 22:46
Oops, sorry ,
Hi Howard,,,,,
FollowupID: 426226
Reply By: Mudness - Thursday, May 04, 2006 at 18:34
G'day Howard, these may be of interest to you or someone else in the process of building a trailer. Ebay # 4637127150
AnswerID: 170699
