Prado info
Submitted: Saturday, May 06, 2006 at 13:57
Dave Thomson
Hi All,
trying to find out consumption on a 3Lt T/Diesel 90 series Prado {02} some say they get 10.5 K's a Lt others say 1200 from both tanks, which cant be as you'd get about 1500 at 10.5 {160 Lts in 2 tanks} anyone know ? also what would you expect to get towing a 1250 K van {Jayco poptop}, and is it advisable to get an oil transmission cooler ? just one more thing, it says to immerse the air filter in
water to clean , does it need to be bone dry before it goes back in ?
thanks in advance,
Reply By: 120scruiser (NSW) - Saturday, May 06, 2006 at 15:57
I haven't got a 90 but I do have a 120 TD.
Fuel consumption is dependant on how fast you go.
Push it over 100 and my fuel economy goes up around the 16 l/100 but on my last trip from
Sydney to Fraser Island with a roof bag on I kept it around the 98km/h and got the best I have ever got, 12.6 l/100.
I use it for work and around town I can't do any better than 15l/100 no matter what I do. All with standard tyres.
I presume the 90 will be similar.
A recent trip via
the rock, alice,
simpson desert etc I travelled 9000km and got 16.1 l/100 and that was with a roof bag, 265/75 x 16 MTR's and loaded to the roof rails. I was pretty happy with that as A/C was on constantly.
I don't tow so I can't answer that question.
I usually sit the air filter on an angle for a while to let most
water drain out and then put it back in. If it is a customers in my workshop, I do the air filter 1st and then let it dry whilst I do the rest of the service. In it goes at the end.
Hope this helps
120scruiser
171153
Reply By: Dave Thomson - Saturday, May 06, 2006 at 17:48
Thanks for that, was'nt sure about the air filter, seemed strange getting it wet,but then I thought it cant do any harm as it's only the centre of it that counts for the air flow aye ?
anyhow the input was helpful, so thanks again,
regards,
171168
Follow Up By: fester3 - Saturday, May 06, 2006 at 18:33
I have an 02 TD and keep a regular check on consumption, and on an everage I get around 11.7 including a bit of town driving. On a trip I usually get a bit better than that but not much. On a recent trip to Fraser island we did a morning's sand driving, including the tracks to the lakes etc and then back to Bris the next day, averaging about 12.5 for the trip. The rig is pretty much a cleanskin excpet for skinny roof bars and bullbar/
426634
Reply By: Member - Phil G (SA) - Saturday, May 06, 2006 at 22:22
Same model as my last vehicle.
Brand new with no accessories and Dunlop tyes it was 10.5 l/100k. After that it was all downhill - add the MTR tyres, roofrack, extra weight,
snorkel etc etc and then you'll get 12.5-13.5 l/100k. All figures cruising at 100 on the highway. Autos do about 1 l/100km worse.
Main
tank is good for about 82 litres; sub for about 64 litres.
Don't worry about the oil cooler - they are a good transmission.
I bought a second air filter - so when one is being washed and dried, I slip the other one in. Takes quite some time for them to dry.
171212
Reply By: djrziggy - Saturday, May 06, 2006 at 23:46
I have same model and get around 750k's on a trip travelling at 100kmh from the main
tank and about 550 ks from sub
tank. It does not seem to make much difference around town to highway travel.
Darren
171230
Reply By: Wizard1 - Monday, May 08, 2006 at 14:26
Dave,
I also have an manual 02 TD. There are so many variables that will effect your figures.
Roof racks
Weight in the vehicle (drawer systems)
Speed
wind
terrain
The best I have got is 10.5 L/100 KM around town. Mind you that was
Darwin where there are good flat roads few traffic lights and an average speed of 80KPH.
On the highway I got the same 10.5 K/100KM. My range at that time was 1000 km It included pasing through
Sydney in morning peak as
well. Avoided 110 KPH as the fuel use was worse and I had no roof rack.
Hook up a trailer or van, load up the roof rack, pack the back and it all becomes academic.....
I also tow a 16 ft Jayco Freedom poptop and average between 13 - 18 L/100KM depending on ambient temp, wind, hills, etc. I tend to drive between 90 - 110 kph. 90 is better for fuel consumption.
Don't get too wrapped up about it. If you do then sell the Prado and van. I just get what I can get but I carry 2 x 20L jerries as backup. My usual range with the jerries can be as good as 900 km with the van. If I get 400 km from the main
tank I'm doing
You need an oiler cooler. The little 4 pot struggles a bit when that clutch fan kicks in so anything to keep your temp down the better.
171516
