Electric brake controllers
Submitted: Wednesday, May 24, 2006 at 11:10
Member - Malcolm P (VIC)
Dear All,
Looking for some info, I am a novice in these areas.
I have recently purchased an off-road camper trailer that is around 1500kgs.
It does have electric brakes but at this stage I have not put a controller in the Patrol.
Currently I have a round 7 pin trailer plug for the 6x4 garden trailer and then an adapter for the flat pin set up on the camper.
Do I go for a Gyro or full electric?
Apart from Tekonsha and Hayman Reece are ther other brands to consider?
What would be a fair price to have installed?
I am in the inner eastern suburbs of
Melbourne.
I would be thankful for all information.
Malcolm
Reply By: djpatrol - Wednesday, May 24, 2006 at 11:37
I have a Kelsey fitted now for 7 years towing a 2 ton van all have some problems I belive, Some brake lock-up on
mine if braking on bumpy roads,I dont know a price now but watch out where they run the wires as they cut my steering colum rubber an I have
water leaking there when it,s wet {{{NOT IMPRESSED}}} on the Patrol.
174421
Follow Up By: Member - Malcolm P (VIC) - Wednesday, May 24, 2006 at 12:46
thanks for the info djpatrol
430521
Reply By: Member - Tony G (ACT) - Wednesday, May 24, 2006 at 11:37
The Tekonsha Prodginy(?) are the pick of them all. My camper is about the same weight as yours and this controller is far better than any others I have used over the years with horse floats etc.
174422
thanks Tony
430523
Follow Up By: Member - Blue (VIC) - Wednesday, May 24, 2006 at 13:01
Another vote here for the Prodigy...
430529
Follow Up By: angler - Wednesday, May 24, 2006 at 20:15
Another vote for prodigy, with yours and others safety involved use the best.
Prodigy.
430629
Follow Up By: Member - John R (NSW) - Wednesday, May 24, 2006 at 20:17
Prodigy. Best controller I've ever used.
430632
Reply By: Patrol22 - Wednesday, May 24, 2006 at 12:33
I use the Aussie made Redarc brake controller and found it to be very good. I pull a Kanga DL 1.4 tonnes laden with a 2.8TDI GU
Redarc
174435
Follow Up By: Member - Malcolm P (VIC) - Wednesday, May 24, 2006 at 12:35
Thanks Patrol 22
I have a Kanga as
well
430517
Reply By: Flash - Wednesday, May 24, 2006 at 14:50
Have used a few, about four or five different controllers on different vehicles including my own, and now have a Tekonsha Prodigy.
As others have said, it's simply the best- there is no contest.
I would not have anything else these days.
174453
Reply By: Nav 8 - Wednesday, May 24, 2006 at 15:21
7 Pin trailer plug will be OK, should only take about hour-hour half to fit,, Nav.
174462
Reply By: Member - Hugh (WA) - Wednesday, May 24, 2006 at 16:22
Malcolm,
On my last Patrol I fitted a Tekonsha Voyager (though consensus is Prodigy is the best).
The current Patrol came with a Redarc unit fitted. I've found this to be much better than the Voyager but cannot comment re the Prodigy. I tow a camper trailer ~ 1.2T fully loaded.
Regards,
Hugh
174473
Reply By: Mikee5 (QLD) - Wednesday, May 24, 2006 at 19:26
Malcolm,
I have a Tekonsha Prodigy too. They are electronic and you can vary the brake pressure to the trailer. The Voyager was having issues a while back in that the vehicle brake lights may come on even with no trailer attached and no-one even in the vehicle!! This has been covered in some of the caravanning forums.
174525
Reply By: Derek from Affordable Batteries & Radiators - Wednesday, May 24, 2006 at 22:12
Malcolm,
The Prodigy is the way to go. I now sell 3 Prodigy's to every Voyager.
The Voyager is still a very good unit and the old brake light problem has been fixed.
The Tekonsha products are great.
Regards Derek.
174566
Follow Up By: Muzzgit (WA) - Wednesday, May 24, 2006 at 22:57
I have the voyager. Great unit. Yes brake light comes on in winter but autoleccy who supplied and fitted it has moved interstate so I don't know how to go about getting it replaced. Instead I have had a plug fitted at the back so I simply disconnect it when not in use.
It was very funny the first time I saw the brake lights on from the kitchen window.....I thought some stooge was breaking into my car, so I tiptoed up the driveway with a baseball bat ready to brake some knuckles. We laughed about it for weeks afterwards.
430658
Reply By: Gerhardp1 - Wednesday, May 24, 2006 at 23:08
Just purchased a prodigy at the
Melbourne show for $150. No point in buying anything inferior when the best is only $150.
174578
