Engel Two Zone - Any comments?
Submitted: Thursday, May 25, 2006 at 07:13
Member - Mike
Hi All
Thinking of getting one of these new Two Zone compartments that fit on top of the Engel fridges - Has anyone that has one of these got any comments re power usage - pratical - freezing etc
Thanks in advance for any feedback
Cheers 4 now
Mike
Reply By: Member No 1- Thursday, May 25, 2006 at 08:00
my thinking says...
the refrigeration all takes place below
cold air falls, warmer air rises
when lid opens warm is drawn in ( slight vacuum/venturi effect) where it stays at the top
dont expect the top product to be very cold....? but it may be very suitable for average ambient temps but must be suspect with higher ambients...to what degree or adverse effect?......some others on here can let enlighten us further
174611
Reply By: Mad Dog (Australia) - Thursday, May 25, 2006 at 09:05
Previous reports on here by users have given this device the thumbs up while reports by non-owners/users give the device the thumbs down....lol, more info by searching.
174625
Follow Up By: Willem - Thursday, May 25, 2006 at 09:13
Very apt, Ray......hahahahahahaha
430698
Follow Up By: Mad Dog (Australia) - Thursday, May 25, 2006 at 12:20
haha, all the theory is
well and good but it's the pratical use that speaks loudest, bit like dual batteries isn't it...can't do this, can't do that,
well I'm bluddy
well doing it and it works for me.
430710
Follow Up By: Member - John C (WA) - Friday, May 26, 2006 at 21:02
I agree with your sentiments. I have a two zone attachment with the 40 litre engel and have travelled extensively with it. The temperature in the top is really good and it gets close to freezing the drinks. I also use the engel external thermometer, placing the probe in the two zone, and place the readout module in the front of the vehicle so I have instant feedback on temperatures.
The height of the two zone may be an issue for some, but with the high roof Nissan Safari it is not an issue.
I believe that they are worth the expense!
JC
431052
Reply By: Willem - Thursday, May 25, 2006 at 09:12
I fitted one yesterday. Still have to test it though. Will let you know in Seprtember when we get back from our Big Trip No 2.
I know Member Number 1 is a Fridgie but to my way of thinking if hot air rises, and you open the top of the unit, that hot air will rise out into space and that ingestion/downdraught of more hot air into the unit would be negligible? Whaddya reckon, Richard?
174628
Follow Up By: Big Kidz (Andrew & Jen) - Thursday, May 25, 2006 at 09:21
Willem - I have thought about one but I am put off by the fact that the fridge works best when it is pretty full so there is little free air space around the things. (Then when you open it it will not lose a great deal of heat.) However, Mr Murphy says that the thing that you want will nearly always be at the bottom and it looks a long way down. Do they have baskets etc that you lift out and how easy is that to do?
430700
Follow Up By: Willem - Thursday, May 25, 2006 at 09:34
Hello Andrew
The Twozone has a basket but it depends on the set-up you have in the vehicle on whether you can remove the basket or not. The Twozone is a clip on unit so it can be lifted to access the stuff in the bottom of the fridge.
430701
Follow Up By: Member No 1- Thursday, May 25, 2006 at 13:16
probably is willem...but..., there is going to be several degrees between the fridge area to the top section.....one needs to measure but my reckoning is that will be more in higher temps but by how much???????...i could borrow yours to test on my engel
430717
Follow Up By: Member No 1- Thursday, May 25, 2006 at 13:23
ohh! you run the fridge as freezer for the bottom?...and the top section becomes a fridge due to heat losses from the top to the very cold lower section?....now that could work....I thought it was just working as fridge...i like my amber nectar and my noggin was thinking that working as a fridge my coopers wasnt going to very cold ...didnt occur to run in freezer mode
430719
Follow Up By: Richard W (NSW) - Thursday, May 25, 2006 at 19:07
Also just purchased a Twozone for the 40L Engel and upgraded the third battery to an AGM 100AH to run everything down the back.
430782
Reply By: Member - ROTORD - Thursday, May 25, 2006 at 10:06
I have used a Two Zone in the
Kimberley and NT , and concur with comments by people who have used them in very hot conditions that they are an efficient and practical unit . The Two Zone comes with its own basket , and the Engel mat is repositioned from the bottom of the Engel to the bottom of the Two Zone basket to create the division between the [ lower ] freezer compartment and the refrigerator . Fill the freezer with pre-frozen product and this forms a 'cold bank ' which aids efficiency . Access to the lower compartment is easy , either by swinging the Two Zone up , or by lifting out the top basket . Freezer will stay frozen if
generator power is applied for 1 hour in morning , and 1.5 hours at sunset . Operation from a dual battery system would be fine , so long as you aren't going to pull down temp of large quantities of unfrozen product . Convenient place for mounting for single or couple of travellers is behind the front passenger
seat , facing forward . This allows access for drinks and snacks from inside the vehicle .
174646
Reply By: Member - Colin (WA) - Thursday, May 25, 2006 at 12:10
Hi Mike,
My parents have just bought one (29l) and tested it for a week before they left for
Broome . Dad was very impressed. He cut a piece of 3mm ply wood to fit in the bottom of the basket to seperate the two temp zones . Talked to a guy who had one and he just uses it as a big fridge he said it was
well worth the money.
Col
174669
Reply By: greydemon - Thursday, May 25, 2006 at 17:30
As these are apparently made in WA they obviously must be good. I would love to have one....but the PRICE! Around $325 for what is basically just an insulated tube with a couple of seals and catches and a wire basket, I just can't justify that sort of expense.
I have an Engel 40ltr which is brilliant. On long trips (which for me means only about 3 weeks unfortunately) I run the Engel as a freezer and carry a cheap Esky to keep things cool. I have two 2 litre plastic bottles of
water which I freeze before leaving home, each morning I swap the bottles over, one into the Engel to re-freeze, the frozen one into the Esky with the frozen food needed that night. The
water bottle and the defrosting food keep the esky nice and cool. Has worked
well for me and I am pretty sure that lots of people do the same.
I have dual batteries which have been in for over two years now and haven't missed a beat, I don't use anything else like solar panels (don't understand them) or generators (can't abide them). However, I rarely
camp in one spot for more than 2-3 nights and usually (but not always) use my vehicle every day which recharges the batteries.
It's the same as everything - if you have the money and will get the use out of it then go for it, I am sure it is a great product - what can go wrong with a tube?
For all the handyman types out there - surely someone can work out how to get the same effect for 20% of the price by cutting the bottom out of an Esky and making a few alterations - I look forward to seeing the instructions on this
forum soon!
174724
Reply By: Jimbo - Thursday, May 25, 2006 at 20:18
I had a 39 L Engel and considered putting a hat on it. I thought $350 for the hat to be a bit over the top.
So I did this....sold the Engel for $650, added the $350 and got an 80 L Waeco from the Fridge
Shop for $990 delivered to my door. Eighteen months on and I'm still happy with my decision. I've got an 80 L job that I can put seperators (supplied) into and can be run as a genuine fridge and freezer or remove the seperators and run it as all fridge.
Bloody versatile unit.
And the Engel with the hat would have been impossible to open in the back of the car.
Just my thoughts and experience for what it is worth.
174746
Reply By: desray - Thursday, May 25, 2006 at 23:16
I have a 39L Engel fridge which is good BUT whatever you want out of it it is allways on the bottom. Everthing comes out of the fridge each time you want somthing ,, putting the two zone compartment on the top would make things twice as bad. I would be thinking about buying another fridge (29L) if you wanted more room and use one as a fridge and one as a freezer
174794
Reply By: Aaron Rowley - Friday, May 26, 2006 at 14:56
My name is Aaron Rowley I work for Twozone, for information on inderpendant testing conducted by Origin Energy in South Australia fell free to visit the twozone website www.twozone.com.au . The areas you will find of interest are the Test results on the toolbar and the storage of fruit and vegtables on the product page.
Also by reading the "How to get the best out of your Twozone" (on prooduct page) you will gain a greater understanding of how the product works and what it is designed to do. Use it for what it has been designed and you never have any problem.
If any body wishes to discuss any information in further please don't hesiate to contact me on 08 9309 2418 I will gladly ring you back to save you the intersate call costs.
Aaron Rowley
174925
Reply By: Member - Robert B (VIC) - Friday, May 26, 2006 at 21:06
Hi Mike,
I currently travelling NT, and bofore leaving home bought the two-zone for my Engel 40. We run the fridge as a freezer and have the two-zone full of drink cans. It takes about 1.5 -> 2 days for the cans to get nice an cold, but the have never frozen.
So the wife is happy - she gets the full 40 litres for food, I get 20L (two-zone) for my stash of drink cans.
Just watch the combined height of two zone on the Engel still opens in your rig.
Yes, they are expensive, but if you wait for a Rays Outdoors sale, you can get 24.5% discount!!
Big thumbs up from me...
Rob
174984
