Series 80 gearbox chatter
Submitted: Tuesday, May 30, 2006 at 08:38
ThreadID: 34402 Views:2325 Replies:1 FollowUps:0
HI
Took my vehicle to have it serviced yesterday and the mechanic asked me how long I have had the gearbox chatter. I had noticed that morning a fairly loud chatter when I had it ideling in the morning. I thought it was the exhaust system as it was pretty cold.
A new clutch was put in a few weeks ago after about 12 months of arguing with the mechanic (differrent one) that the one he put in 12 months was not acceptable as the vehicle was lurching in both forward and reverse rather dangerously when taking off on some occasions.
When its warmed up there is no noise and also when the clutch is depressed which would I suppose be normal.
The mechanic said that its not a bad problem and I if I can to put up with it leave it?
My questions are -
Is the mechanic right or can it be fixed without great expense?
Is this a common problem with series 80s.
Could the old clutch have caused some damage somewhere?
Howard
Reply By: Member - DOZER- Tuesday, May 30, 2006 at 10:09
Gday...could be many things....start by pulling the fast idle lever in the morning, as the motor will be idling slower...this should stop the chatter....check the gearbox oil plug for signs of metal...but i suspect that the other mechanic has put a clutch in with loose springs..(probably your old one)..and they are rattling round
AnswerID: 175591
