Hypervent mattress underlay
Submitted: Thursday, Jun 01, 2006 at 08:29
ThreadID: 34495 Views:10340 Replies:2 FollowUps:7
Has anyone been using this to stop the condensation under the CT mattress? Just after some feedback, bit expensive, but then it saves "Airing" the mattress out all the time.
Reply By: traveller2 - Thursday, Jun 01, 2006 at 10:39
A piece of low (60%) shadecloth works just as well, two layers if you want more airflow.
We ended up getting camper innerspring mattress from Made to Measure mattresses in Qld, it is one sided and has large vents to circulate the air.
No connection to the company just a satisfied customer.
AnswerID: 176110
Follow Up By: Member - uncle - Thursday, Jun 01, 2006 at 11:22
Thanks for the tip Traveller will give it a try! cheers ,I have heaps of it sitting in the garage!
FollowupID: 432145
Follow Up By: Moose - Thursday, Jun 01, 2006 at 13:16
G'day uncle and traveller2
I'm totally new to the CT game (only slept in it one night so far) so please excuse any dumb questions/comments. Please explain why one would get mositure under the mattress (wouldn't the wooden floor soak up any moisture?). And then how the hell would a thin piece of shadecloth create airflow?
Also traveller2 the mattress you bought sounds like it's something specific to CTs. What does "it is one sided" mean? How thick is it? Approx. cost?
Thanks in advance.
FollowupID: 432159
Follow Up By: Member - uncle - Thursday, Jun 01, 2006 at 13:46
Hi Moose,the moisture is caused from the foam mattress absorbing body moisture and then dumping it on the under side of the mattress for some unknown reason. At $56 a sq metre, I'm willing to try the shade cloth instead of the good stuff first.I dont want moisture in the timber floor though as it stinks after some time.!Cheers
FollowupID: 432165
Follow Up By: Vince NSW - Thursday, Jun 01, 2006 at 15:52
We went the way of the innerspring and have not had the problem again.
Cost was around $475
.vince
FollowupID: 432179
Follow Up By: snailbait (Blue mntns) - Friday, Jun 02, 2006 at 09:11
hi all
I have a CT and Roof top tent one has a timber floor and the CT has a steel floor i tried the shade cloth and did not like the lattice timber and we bit the bullet and forked out aprox $130.00 for plastic coated steel under mattress airer and we have not had any trouble since a further trick like we did in the Roof top tent was to have a mattress in a vynle cover like the hospital has then we did not have any troble with moisture under the matress
snailbate
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
FollowupID: 432289
Follow Up By: traveller2 - Monday, Jun 05, 2006 at 08:28
The mattress is one sided to keep the thickness down as the springs are 100mm +40mm or so of cover/quilting on one side so it will fit as most campers/rooftop tents don't have enough height for a normal double sided innerspring mattress when closed.
Was just over $300 delivered from memory.
FollowupID: 432801
Reply By: Member - Roachie (SA) - Monday, Jun 05, 2006 at 11:06
G'day Uncle,
We have a Ultimate Camper Trailer which has a fibre-glass bed base. We suffered from on the underside of the mattresses initially and got the good people at Ultimate to fit a 2m x 2m square of that "Hypervent" stuff to the lid (at least I'm assuming that's the name of the stuff they fitted).
All I can say is "IT WORKS"!!!!!
We had it done several years ago, I can't remember how much it cost....it was several hundred $$$ at least!!! But, as they say, "Buy once, buy well"........or ....... "If you buy a quality product, price is soon forgotten".
Having had it for the past several years, you may interested to know that there is no sign whatsoever of this stuff compacting down over time......it's still as good as ever.
Roachie
AnswerID: 176777
Follow Up By: Member - uncle - Monday, Jun 05, 2006 at 20:58
Sounds good will prob look into that stuff later, thanks Roachie.
FollowupID: 432938
