AnswerID: 176142 Submitted: Thursday, Jun 01, 2006 at 16:06
bobsa
replied:
Hi Snowy,
I had the same problem with my 3.0L GU 4
There is no adjustment on the back of the speedo.
The driven gear is very easy to change. Find the sensor on the back of the gear box on the extension housing, there is a 10mm bolt remove that and pull it out a small amout of oil will be lost, I just plugged it with a piece of rag.
There is a small circlip remove this and the cog can be removed and changed to suit your needs.
Here is a list of part numbers for the cogs
32743-74P18..........18 tooth
32743-VB017..........17 tooth
32743-VB016..........16 tooth
32743-VB015..........15 tooth
the original cog in the GU 4 with 17" standard rims is a 16 tooth, went to 285 75 16 and changed to a 15 tooth cog and the speedo now read about 4 km fast.
Reply 5 of 7
