Spare Part List for Landcruiser 100
Submitted: Thursday, Jun 01, 2006 at 16:06
Dirk 32
Hi there,
I was wondering if anyone made a list of spare parts, which you should take on a 4-6 months trip around Oz. Any advice on what turned out to be usefull or useless would help. Vehicle is a
Landcruiser 100 GXL TD, latest model
Thank you very much in advance for sharing your knowledge and resources.
Dirk
Reply By: signman - Thursday, Jun 01, 2006 at 16:33
For a Landcruiser 100 GXL TD, latest model...geez mate- you'll need a b-double following you to carry all the spares needed!!!
176146
Follow Up By: Richard W (NSW) - Thursday, Jun 01, 2006 at 16:49
So signman what do you recomend? I've got a few ideas but lets hear yours first.
432188
Follow Up By: signman - Friday, Jun 02, 2006 at 10:27
G'day Richard
I wish the Barramundi would bite as good as you :-)
432310
Follow Up By: Richard W (NSW) - Friday, Jun 02, 2006 at 11:33
Theres none it that mudhole mate. lol
Still like to hear what you carry?
432325
Reply By: 100TD - Thursday, Jun 01, 2006 at 17:02
i recently came back from a 6 week outback/desert run in my 03 TD and required nothing not even a flat,as long as the vehicle is set up for where and what you want to do it will be fine cheers Paul
176155
Reply By: Member - Stan (VIC) - Thursday, Jun 01, 2006 at 17:06
It is all depends how remote are you planning to go....
Gloves, 2 straps, jack, jacking plate, rated hooks,2 x bow shackles.
Tyre gauge, Air Compressor, Sand Flag
Radiator hoses - top and bottom, heater hose
serpantine belt, fuel filter, air filter,
wheel nuts and studs,
1lt engine,gearbox/diff/trans oil
Spare shocker washers, rubbers, locators, and mounting bolts including spare front and rear shock
2 spare tyres, tyre repair equipment
Rated recovery points front and rear
176157
Follow Up By: Dirk 32 - Thursday, Jun 01, 2006 at 21:21
Thank you Stan,
Most of the items mentioned are already on the list, incl spare hoses and belts. But I wouldn't take spare 2 spare shocks, but I hope with a recently fitted aftermarket
suspension I should be fine... or at least I pretty much hope so.
Dirk
432242
Follow Up By: Member - Stan (VIC) - Thursday, Jun 01, 2006 at 21:44
Dirk,
As I said depends how remote you are going. The spare shocks are mainly for
offroad travels like CSR/Simpson Desert/etc... BTW, what brand of
suspension did you ended up getting?
Stan
432247
Follow Up By: Richard W (NSW) - Friday, Jun 02, 2006 at 07:41
I also carry amongst other things spare bits and pieces like fuses nuts and bolts etc.
5min araldite, fencing wire, duct tape, plastic ties. It's amazing what you can fix with these things.
432270
Reply By: ev700 - Thursday, Jun 01, 2006 at 18:50
Dirk32
For the usual run around the block plus deviations you don't need spares, just regular good servicing.
There are plenty of service centres and that is a common vehicle.
More likely a vehicle would fail in a city where it does the slow stuff in traffic.
If you get interested in tough stuff in remote areas you are better off tagging along with an experienced person or club and in that case you would be getting some experience and training up-front which would include vehicle set-up, supplies, communications and so on.
Along with thousands of others I've towed vans around Oz with family sedans in the early 70's when roads were much less
well-developed. Never had a problem. Our 100 Series 4.2 TD is a luxury behemoth compared with a secondhand sixties Falcon auto.
I am amazed at the largely unnecessary fitout (and weight) of the fourbies cruising Oz. They are testament to the power of aftermarket equipment advertising. With the greatest respect to all concerned, the aftermarket stuff breaks before the vehicle though.
Use common sense, have fun and don't sweat it.
176179
Reply By: Dirk 32 - Thursday, Jun 01, 2006 at 21:17
Thank you to all your replies so far.
Just in case we might have had a little misunderstanding. Of course I will apply common sense and of course the vehicle will be fitted out accordingly to what we intend to do.
I was simply looking for some kind of useful feedback on real spare parts only. Of course we will have the appropriate recovery gear and I agree, that with a relatively new 4WD we shouldn't experience too much trouble.
Nevertheless I always like to hear other opinions.
Thank you, Dirk
176211
