Inverter probs
Submitted: Thursday, Jun 01, 2006 at 19:22
Wilankurgab
Sorry, first timer here with problems! I have a 1000w MSW inverter powered by a 115ah Trojan. I am trying to run a bar fridge in my on road camper trailer. The bar fridge draws 77w or 0.5amp. I understand it may need 500w to start hence the 1000w inverter with 2000w surge. Anyway most of the time either the audible fault indicator on the inverter is triggered or the "thermal cutout"(probably wrong terminolgy) on the fridge kicks in.
After testing with my you beaut tester I have 14.1v at the inverter and 238v at the switch to the fridge.
Any ideas?
Reply By: lunchbuckett - Thursday, Jun 01, 2006 at 19:57
Wilankurgab if it is compressor type and the size of the capasitor by my calc it will take 1500 w to start
176186
Follow Up By: Wilankurgab - Thursday, Jun 01, 2006 at 20:15
Thanks for that. Considering the inverter has a 2000w surge should that cover it?
Also if not a trade secret how do the calcs work?
432228
Reply By: Keith_A (Qld) - Thursday, Jun 01, 2006 at 20:20
What cable size are you running from the battery to the inverter?
If it needs 500w to start - then at 12V it draws 41 amps.
If the cable length is say 2.5m to your battery, total cable (neg + pos) = 5m
- max voltage loss = 0.36V
0.36 = length x amps x .017 / (cross section wire conductor)
.36 = 5 x 41 x .017 x wire / (cross-section)
Thus Wire cross section = 10sq mm cable.
This is the copper cross sectional area, NOT the automotive size.
Check this website : caravanandmotorhomebooks.com/articles/wiring_woes.htm
If the wiring from the battery to the inverter is too small, the voltage drop at the inverter (at start up of the fridge) would cause the 'low voltage' error'.
Could this be the problem?
regards.................Keith
176191
Follow Up By: Wilankurgab - Thursday, Jun 01, 2006 at 20:26
Gday Keith, thats starting to make sense. I have battery type cables connected with a 150amp fuse inline on the positive. The length is only 600mm.
Cheers Wilankurgab
432230
Reply By: Geoff (Newcastle, NSW) - Thursday, Jun 01, 2006 at 20:46
What everyone else has said is fair and reasonable.
Another area to look at,
Will the fridge actually run on any Modified Sine Wave Inverter?
It may not have anything to do with voltage drop, starting or inrush current at all.
There's all sorts of sine wave dependent physics going on when you start a split phase motor.
Are you able to beg borrow or generally obtain a Pure Sine Wave in a similar size?
Or just as good a Kipor, Honda or Yamaha inverter style 1kva generator will soon eliminate the problem of Modified v's Pure Sine Waves.
Geoff.
| Geoff,
176204
Reply By: Member - Doug T (QLD) - Thursday, Jun 01, 2006 at 22:13
Wilankurgab
You have to have BEER in the fridge mate
176232
Reply By: Member - George (WA) - Thursday, Jun 01, 2006 at 23:01
Wilankurgab
Get the battery tested, the voltage may be OK but it may fail under load. I had the same problem as you explained, purchased a new battery, problem solved
176245
