Jack Gearbox - Thread 34504
Submitted: Friday, Jun 02, 2006 at 20:19
ThreadID: 34553 Views:2784 Replies:7 FollowUps:1
Thanks for all the advice and suggestions - We took it to a GM dealer today and all they could offer was a $95 plug in to the computer to test the electronics - no mechanical info. They also admitted they know little about Jacks, only see about one a month for servicing - Interesting - This is a big GM dealer in Parramatta.
They then offered to give us the name and address of transmission specialist they use.
Went around there and what a difference - plugged some computer in immediately and established it was not electronic.
Offered to service it immediately which we agreed to.
Result
In their opinion it had never had oil serviced or replaced, very small amount in it and that had the wrong smell. They then too off the sump and inspected things.
Filter was totally blocked
(Is this a part of the GM servicing program - the car has been serviced by GM since new?)
There is a magnet in the sump housing and it was covered in grey stuff METAL
They then asked me if we were planning to sell it.
Offered (if need be) a rebuild for $2400 including parts and labour.
They replaced gasket, new filter, filled it with oil and set us on our way.
We are now waiting to see what happens over the next couple of days.
One interesting thing we noted - There is a magnet to collect shavings etc in the sump - Presumably it is expected that that will happen - My question is - Is that normal.
They also told us the car will tell us before it gives up - Either with warning light or further funny things like we have just experienced.
Again our thanks to all
Reply By: Peter 2 - Friday, Jun 02, 2006 at 20:35
I take my auto's to a local auto trans place once a year for a service, they pull the sump off, clean the filter, replace fluid as required. While this doesn't replace all the fluid it does get rid of any crap and also show indications of problems before they cause failure.
The trans shop can do a full flush and change if the vehicle is subject to heavy use like towing if required. Typically costs less than $100.
My old turbo Volvo is well on the way to 400,000k with the original auto which has had no work done on it yet.
The Humvee is only a baby with less than 80k miles and an indestructible T400 auto.
AnswerID: 176441
Reply By: Willem - Friday, Jun 02, 2006 at 21:39
As far as I know most sump and gearbox/transfercase drain plugs are magnetised to catch any metal filings which may become dislodged inside the boxes and so to prevent them from causing further damage.
AnswerID: 176457
Reply By: Darian (SA) - Saturday, Jun 03, 2006 at 07:52
Magnetic plugs are common in most cars - there is always something on them (mostly very fine, and not much) when I change my oils - if there was nothing there ever, your box would never wear out. Re the appearance of gross neglect in your auto box servicing - many dealers are into organised "artful servicing". Its technically fraud in my view- taking your money, for work not done - very common in the industry, if reports here are anything - and I've had first hand experience. If paying forservices, you should spot-check the drain plugs and access points on the underside, to satisfy yourself that there has at least been some activity there - people have been amazed over the years to find undisturbed drain plugs, while havng paid for new oils !
AnswerID: 176495
Reply By: Jodi - Saturday, Jun 03, 2006 at 10:55
Don't know much about Jacks. We drive Hilux however have friends with Jack. They're quite happy with it. Although when there was a problem for them Amberly Autos in Dandenong were fantastic. No affiliation, I've never used them but have heard many good things and had many recommendations to them.
AnswerID: 176505
Reply By: Exploder - Saturday, Jun 03, 2006 at 13:33
(Is this a part of the GM servicing program - the car has been serviced by GM since new?)>
I would say No, A lot of manufactures like to overestimate how good there engineering is and how good the oil is, so on things like auto gear boxes it is common for it to be a no service item unless it is leaking or a problem occurs like in your case, But by that time it is often to late.
I Know Ford for one and am sure Holden GM do it as well, say that the Auto gearboxes do not require a service or fluid change for the life of the car unless a leak is suspected or a problem occurs. What a compete load of rubbish, I did a full fluid flush (12.5 litres) at 120,000k and the Transmission fluid was brown.
Yeah you will feel it going, things like not changing up gears or slipping< Clunky changers Etc but once this occurs it can take a year or a week to pack in, it’s anyone’s guess.
AnswerID: 176515
Reply By: Member - Jeff M (WA) - Saturday, Jun 03, 2006 at 13:37
My mates 3.5L auto Jack was a bit rough in the gears so he took it to a reputable auto tranny place for a service. They took the cover off and showed him all these filing on the magnet telling him doom and gloom and how expensive "these things are" and that it's on the way out.
Maybe, but he done over 20k since and since they changed the oil (probally the 1st one it had in it's life at 175k!!) it's been good as gold. Smooth and the rest.
I reckon if you were to stick a magnet in ANY gearbox oil that had been in there for 175k without being changed you'd have a few filings on there....
AnswerID: 176516
Reply By: Sparkiepete - Sunday, Jun 04, 2006 at 09:11
When I bought my Jackaroo with 220.000K on the clock the first thing I did was change all the oils in the drivetrain.
Now mine a manual so it wont be your problem but I noticed when I changed the rear diff oil some significant pieces of metal came out with the oil change.
Panicking a little thinking i had bought a lemon I enquired about a rebuild for my diff. Having blown most of my money on the purchase a rebuild was out of the question.
So I thought stuff it, if it fails I will worry about it then. 260.000k on the clock and still going strong.
I don't think a few shavings are going to matter as I cannot recall to many people talking about failed gearboxes and the like in Jackaroos in general.
Keep up the servicing and it will probably run for a long time. If you are worried try to find forums on Jackaroos and see if other poeple have had this problem.
Sparkiepete
AnswerID: 176607
Follow Up By: WDR - Sunday, Jun 04, 2006 at 19:26
See my new post of today
FollowupID: 432737
