injector problem
Submitted: Saturday, Jun 03, 2006 at 20:28
ThreadID: 34576 Views:1763 Replies:3 FollowUps:0
I have a 2002 Jackaroo turbo diesel which has done 60000 km without any problem.my mate has the same car with 80000km on the clock and has had the injectors replaced twice under warranty,he has now experienced the problem again .
Has any one had a similar problem ,are injectors a fault with the Jackaroo turbo diesel.
Any one have any information.
Reply By: Markymark - Saturday, Jun 03, 2006 at 20:40
I believe it's something along the lines of the injectors are driven by the oil pressure and if the incorrect grade of oil is used, there can be problems of all sorts.
AnswerID: 176555
Reply By: Member - Bruce and Anne - Saturday, Jun 03, 2006 at 20:49
The problem is not the injectors but the injector seals, and Holden should have fixed this under a recall. It was a big problem with the 3.0 litre in the first ones that they producted. So tell him to take it to Holden and see what they say.
Cheers Bruce
AnswerID: 176558
Reply By: Darian (SA) - Sunday, Jun 04, 2006 at 10:01
Indeed - as Bruce says - it was the injector seals - they we recalled on the basis of safety, because the leak could cause the motor to surge and had the potential to toss people into a "situation". Mine have been done twice on recall (or so the dealers said - while it was in for otherwork - but I've never had an issue with the injectors causing problems - vehicle has been good overall so far - beig essentially a safety issue, there may be no limitation on when it can be done - any dealer should be able to bring your VIN number up on their national tracking system, and see if the seals have been done at some stage. I think my second recall was for a revised, improved type of seal (once again, so the dealer involved "said").
AnswerID: 176617
