battery charging
Submitted: Monday, Jun 05, 2006 at 11:13
ThreadID: 34626 Views:3192 Replies:3 FollowUps:1
Morning all,
Just wanted some advice on charging from a 12volt dc outlet on generator.
Would it be possible to attach a 10amp solar regulator between the 12 volt outlet and battery to elliminate the chance of overcharging the battery. I know that It would be better to use a 240 volt charger, but I want to keep the use of the generator to a minimum, Time wise. Any assistance would be appreciated.
Chris
Reply By: Alloy c/t - Monday, Jun 05, 2006 at 11:39
Put your solar regulator on your 12v outlet on your genny at your own risk ,, 99.9% chance you will stuff the regulator ,,,Steca regulators specificaly advise against doing so with their regulators.
AnswerID: 176785
Follow Up By: disco1942 - Monday, Jun 05, 2006 at 13:20
Chris
What generator are you using? If you intend to use the 12V output from a Honda or Yamaha generator then these are not capable of fully charging a battery let alone over charge it. These outputs will however put enough charge into a flat battery to get enough life to start a 4WD motor or get another night out of the battery for a fridge.
FollowupID: 432846
Reply By: Geoff (Newcastle, NSW) - Monday, Jun 05, 2006 at 14:17
Hi Chris,
K-Mart and I think Super Cheap sell a black box the name of which totally escapes me that converts an old linear battery charger into a 2 stage charger.
I see no particular reason why you couldn't use one of these to charge from the 12 volt outlet on your generator.
Ideally if you are going to spend the money on a regulator put a little more to it and buy a good 240volt 3 stage charger and you can use it at home too. The other bonus is you'll get a lot more than the 8 amps most of these generators spit out.
Geoff.
Geoff,
AnswerID: 176817
Reply By: Derek from Affordable Batteries & Radiators - Monday, Jun 05, 2006 at 19:25
Hi Rooster,
Most solar regulators short ciruit the current to regulate the flow. Using a solar regulator on the genny would damage the reg and possibly the generator windings.
Rather wire a automotive regulator onto the genny or an aftermarket regulator.
Regards Derek.
AnswerID: 176895
