Mini Generators
Submitted: Friday, Feb 21, 2003 at 12:13
ThreadID: 3473 Views:2009 Replies:3 FollowUps:1
Has anyone had experience with either the Christie Engineering or LightHorse mini generators?
Reply By: Member - NOBBY - Friday, Feb 21, 2003 at 13:44
ROHAN.. I HAVE JUST PURCHASED (3 MONTHS AGO) A CHRISTIE "GEN " SET. I BROUGHT THE LARGER SET THAT GIVES 120amp AND TO DATE I COULD NOT BE HAPPIER WITH IT. I CHOSE THE LARGER SET OBVIOUSLY BECAUSE OF THE OUTPUT BUT ALSO BECAUSE IT IS CONDSIDERABLY QUITER THAN THE SMALLER SET (50amp I THINK) . THEY COST $1234.00 FROM SPRINGERS IN BRISBANE( 0438 789 113). THEY WEIGH 18KG AND ARE FAIRLY SMALL( I KEEP MINE IN A WHITE PLASTIC BOX WHEN TRAVELLING) ( 512X304X402). MOTOR IS A HONDA GX100 AND RUNS FOR I.25 HRS ON 1.2 LITRES. I RUN TWO 100amp DEEP CYCLE BATTERIES FOR FRIDGE/ FREEZER AND EVERY THIRD DAY CHARGE THEM FOR 1 TANK OF FUEL: RESULT FULLY CHARGED. HOPE THIS HELPS. REMEMBER THEY ARE ONLY 12v THOUGH.
AnswerID: 13645
Reply By: Bob Y. - Friday, Feb 21, 2003 at 14:59
Rohan, There's been heaps of comments on the Christie, on this forum over the past few months, lot less on the Lighthorse. If Ozi was here, he would put you right, on the efficient way to charge deep cycle batteries. Hooroo...
AnswerID: 13656
Follow Up By: Member - Rohan - Friday, Feb 21, 2003 at 15:41
Thanks. Did a search and read the comments. For me (and I'm sure for any camping neighbors) silence is golden so I think that excludes the current model Christie. I'll look at solar again.
FollowupID: 8048
Reply By: dougie - Wednesday, Feb 26, 2003 at 00:48
have a look at the honda inverters Very quite, cheap 4 stroke to run
AnswerID: 13959
