Mounting of Radio in GU Patrol
Submitted: Sunday, Jun 11, 2006 at 12:48
ThreadID: 34820 Views:2451 Replies:7 FollowUps:0
To save me "re-inventing the wheel" where do people mount the transceiver body in GU Patrol?
I have a place for the remote head.
Reply By: Member - Troll 81 (QLD) - Sunday, Jun 11, 2006 at 13:03
I have put mine under the dash with some tie downs....out of sight and works well
AnswerID: 177941
Reply By: fnq triton - Sunday, Jun 11, 2006 at 13:53
i unscrewed the glove box(4 screws) on the triton and then zip tied it under the dash. not sure if the patrol is the same but it works really well and is easy to hear.
AnswerID: 177948
Reply By: 10 Para (Qld) - Sunday, Jun 11, 2006 at 14:07
Hi anglepole,
We have B;lackwidow drawers fitten in the rear, when the draws get fitted there is a great space each side of the wheel arch's we on the kerb side we have fitted extra battery in the front and at the rear the HF rado it fits just great and has been there for 3 years now and no trouble at all.
AnswerID: 177949
Reply By: Member - Matt M (ACT) - Sunday, Jun 11, 2006 at 18:08
If you have a cargo barrier, fitting it to the rear of the barrier works well. Good ventilation and up high should water become a problem.
AnswerID: 177975
Reply By: Muzzgit (WA) - Sunday, Jun 11, 2006 at 21:51
I have a large old commercial UHF which I have mounted on the rear of the centre console. I took out the ashtray [ won't be needin that anymore, cough cough ] and mounted the UHF and a 12v outlet for the fridge.
Seats in, seats out, doesn't matter, it's not in the way and cannot be seen from outside the car. Mic cable is cable tied to the hand brake and power comes from under glovebox and thru the middle.
AnswerID: 178011
Reply By: Member - Steve & Paula - Sunday, Jun 11, 2006 at 23:02
Hi Anglepole,
In my GU, I mounted the body of the CB under the centre console, you can remove the panels in the rear and mount it under the tray. I ran the cables up through the hand brake opening. You will need an external speaker though.
Steve
AnswerID: 178018
Reply By: Patrol_Driver - Monday, Jun 12, 2006 at 18:23
I replaced the standard double DIN CD player with a single DIN MP3 player (can get 12 albums onto 1 CD so it beats a stacker). I then mounted my UHF radio in the spare slot.
AnswerID: 178109
